Workflow when purchasing an ONTAP Select license
The following workflow illustrates the process of purchasing and applying a license for your ONTAP Select deployment. When purchasing a license, you must select the licensing model and storage capacity.
The exact process varies based on whether you are using a Capacity Tier or Capacity Pool license:
- Nine-digit license serial number
Serial number applies to either a node (Capacity Tiers) or a storage pool (Capacity Pools)
- License Lock ID
You must have the License Lock ID for your Deploy instance when using a Capacity Pool license
- Licensing web site
You obtain a Capacity Tier and Capacity Pool license at different web sites
Related information
