ONTAP Select
Create an ONTAP Select single-node evaluation cluster on ESXi
Contributors netapp-revathid
You can deploy a single-node ONTAP Select cluster on a VMware ESXi host managed by vCenter. The cluster is created with an evaluation license.
The cluster creation workflow differs in the following situations:
  • The ESXi host is not managed by vCenter (standalone host).
  • Multiple nodes or hosts are used within the cluster.
  • The cluster is deployed in a production environment with a purchased license.
  • The KVM hypervisor is used instead of VMware ESXi.
Step 1: Register vCenter server credential
When deploying to an ESXi host managed by a vCenter server, you need to add a credential before registering the host. The Deploy administration utility can then use the credential to authenticate to vCenter.
Category HTTP verb Path
Deploy
POST
/security/credentials
Curl
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step01 'https://10.21.191.150/api/security/credentials'
JSON input (step01)
  "hostname": "vcenter.company-demo.com",
  "type": "vcenter",
  "username": "misteradmin@vsphere.local",
  "password": "mypassword"
Processing type
Asynchronous
Output
  • Credential ID in the location response header
  • Job object
Step 2: Register a hypervisor host
Add a hypervisor host where the virtual machine containing the ONTAP Select node will run.
Cluster
POST
/hosts
Curl
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step02 'https://10.21.191.150/api/hosts'
JSON input (step02)
  "hosts": [
      "hypervisor_type": "ESX",
      "management_server": "vcenter.company-demo.com",
      "name": "esx1.company-demo.com"
Processing type
Asynchronous
Output
  • Host ID in the location response header
  • Job object
Step 3: Create a cluster
When you create an ONTAP Select cluster, the basic cluster configuration is registered and Deploy generates the node names automatically.
Cluster
POST
/clusters
Curl
You should set the query parameter node_count to 1 for a single-node cluster.
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step03 'https://10.21.191.150/api/clusters? node_count=1'
JSON input (step03)
  "name": "my_cluster"
Processing type
Synchronous
Output
  • Cluster ID in the location response header
Step 4: Configure the cluster
You must provide the following attributes as part of configuring the cluster.
Cluster
PATCH
/clusters/{cluster_id}
Curl
Provide the cluster ID.
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step04 'https://10.21.191.150/api/clusters/CLUSTERID'
JSON input (step04)
  "dns_info": {
    "domains": ["lab1.company-demo.com"],
    "dns_ips": ["10.206.80.135", "10.206.80.136"]
    "ontap_image_version": "9.5",
    "gateway": "10.206.80.1",
    "ip": "10.206.80.115",
    "netmask": "255.255.255.192",
    "ntp_servers": {"10.206.80.183"}
Processing type
Synchronous
Output
None
Step 5: Retrieve the node name
The Deploy administration utility automatically generates the node identifiers and names when a cluster is created. Before you can configure a node, you need to retrieve the assigned ID.
Cluster
GET
/clusters/{cluster_id}/nodes
Curl
curl -iX GET -u admin:<password> -k 'https://10.21.191.150/api/clusters/CLUSTERID/nodes?fields=id,name'
Processing type
Synchronous
Output
  • Array records each describing a single node with the unique ID and name
Step 6: Configure the nodes
Provide the basic configuration for the node, which is the first of three API calls used to configure a node.
Cluster
PATH
/clusters/{cluster_id}/nodes/{node_id}
Curl
Provide the cluster ID and node ID.
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step06 'https://10.21.191.150/api/clusters/CLUSTERID/nodes/NODEID'
JSON input (step06)
Provide the host ID where the ONTAP Select node will run.
  "host": {
    "id": "HOSTID"
  "instance_type": "small",
  "ip": "10.206.80.101",
  "passthrough_disks": false
Processing type
Synchronous
Output
None
Step 7: Retrieve the node networks
Identify the data and management networks used by the node in the single-node cluster. The internal network is not used with a single-node cluster.
Cluster
GET
/clusters/{cluster_id}/nodes/{node_id}/networks
Curl
curl -iX GET -u admin:<password> -k 'https://10.21.191.150/api/ clusters/CLUSTERID/nodes/NODEID/networks?fields=id,purpose'
Processing type
Synchronous
Output
  • Array of two records each describing a single network for the node, including the unique ID and purpose
Step 8: Configure the node networking
Configure the data and management networks. The internal network is not used with a single-node cluster.
Note Issue the following API call two times, once for each network.
Cluster
PATCH
/clusters/{cluster_id}/nodes/{node_id}/networks/{network_id}
Curl
Provide the cluster ID, node ID, and network ID.
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step08 'https://10.21.191.150/api/clusters/ CLUSTERID/nodes/NODEID/networks/NETWORKID'
JSON input (step08)
Provide the name of the network.
  "name": "sDOT_Network"
Processing type
Synchronous
Output
None
Step 9: Configure the node storage pool
The final step in configuring a node is to attach a storage pool. You can determine the available storage pools through the vSphere web client, or optionally through the Deploy REST API.
Cluster
PATCH
Curl
curl -iX PATCH -H 'Content-Type: application/json' -u admin:<password> -k -d @step09 'https://10.21.191.150/api/clusters/ CLUSTERID/nodes/NODEID'
JSON input (step09)
The pool capacity is 2 TB.
  "pool_array": [
      "name": "sDOT-01",
      "capacity": 2147483648000
Processing type
Synchronous
Output
None
Step 10: Deploy the cluster
After the cluster and node have been configured, you can deploy the cluster.
Cluster
POST
/clusters/{cluster_id}/deploy
Curl
curl -iX POST -H 'Content-Type: application/json' -u admin:<password> -k -d @step10 'https://10.21.191.150/api/clusters/CLUSTERID/deploy'
JSON input (step10)
Provide the password for the ONTAP administrator account.
  "ontap_credentials": {
Processing type
Asynchronous
Output
  • Job object
