ONTAP Select
Acquire an ONTAP Select Capacity Tier license
Contributors netapp-revathid
When using Capacity Tiers licensing, you need to acquire a license file for each ONTAP Select node. The license file defines the storage capacity for the node and is locked to the node through the unique nine-digit serial number assigned by NetApp.
Before you begin
  • You must have the nine-digit license serial number assigned to the ONTAP Select node by NetApp.
  • You should wait at least 24 hours after the shipped date of your purchase order before acquiring a license file.
  • You have reviewed the considerations for sizing a Capacity Tiers license.
About this task
You must perform this task for each ONTAP Select node requiring a Capacity Tiers license.
Steps
  1. Access the ONTAP Select license site.
  2. Sign in using your NetApp account credentials.
  3. On the License Generator page, select the desired license offering from the dropdown box.
  4. Fill in the remaining fields on the License Generator page, including the Product Serial #.
    The "product serial #" is the serial number for the ONTAP Select node.
  5. Select Submit.
  6. After the request has been validated, select the delivery method for the license.
    You can select either Download License or Email License.
  7. Confirm that you received the license file based on your selected delivery method.
After you finish
You must upload the license file to the Deploy administration utility before it can be applied to an ONTAP Select node.
