ONTAP Select
Upgrade to VMware ESXi 8.0 or later for ONTAP Select
Contributors netapp-pcarriga
If you are running ONTAP Select on VMware ESXi, you can upgrade the ESXi software from an earlier supported version to ESXi 8.0 or later. Before upgrading, you should understand the process and select the appropriate upgrade procedure.
Prepare to upgrade VMware ESXi
Prepare and select the upgrade procedure that is appropriate for your environment before upgrading the ESXi software on the hypervisors hosting an ONTAP Select cluster.
Steps
  1. Become familiar with how to upgrade VMware ESXi
    Upgrading the ESXi software is a process described and supported by VMware. The hypervisor upgrade process is part of the larger upgrade procedure when using ONTAP Select. Refer to the VMware documentation for more information.
  2. Select an upgrade procedure
    Several upgrade procedures are available. You should select the applicable procedure based on the following criteria:
    • ONTAP Select cluster size
      Both single-node and multi-node clusters are supported.
    • Use of ONTAP Select Deploy
      Upgrade is possible both with and without the Deploy utility.
      Tip You should select an upgrade procedure that uses the Deploy administration utility.
      Performing an ESXi upgrade using the Deploy administration utility is the more general and resilient option. However, there might be instances when Deploy is unavailable or cannot be used. For example, upgrading to ESXi 8.0 is not supported with earlier versions of ONTAP Select and the Deploy administration utility.
      If you are using these earlier versions and attempt an upgrade, you can leave the ONTAP Select virtual machine in a state where it cannot be booted. In this case, you must select an upgrade procedure that does not use Deploy.
  3. Upgrade the Deploy administration utility
    Before performing an upgrade procedure using the Deploy utility, you might need to upgrade your Deploy instance. In general, you should upgrade to the most recent version of Deploy. The Deploy utility must support the version of ONTAP Select you are using. Refer to the ONTAP Select release notes for more information.
  4. After the update procedure is complete
    If you select an upgrade procedure that uses the Deploy utility, you should perform a cluster refresh operation using Deploy after all of the nodes have been upgraded. See Refreshing the Deploy cluster configuration for more information.
Upgrade a single-node cluster using Deploy
You can use the Deploy administration utility as part of the procedure to upgrade the VMware ESXi hypervisor hosting an ONTAP Select single-node cluster.
Steps
  1. Sign in to the Deploy utility CLI using SSH with the administrator account.
  2. Move the node to the offline state:
    node stop --cluster-name <cluster_name> --node-name <node_name>
  3. Upgrade the hypervisor host where ONTAP Select is running to ESXi 8.0 or later using the procedure provided by VMware.
  4. Move the node to the online state:
    node start --cluster-name <cluster_name> --node-name <node_name>
  5. After the node comes up, verify that the cluster is healthy.
    Example:
    ESX-1N::> cluster show
    Node           Health  Eligibility
    sdot-d200-011d true    true
After you finish
You should perform a cluster refresh operation using the Deploy administration utility.
Upgrade a multi-node cluster using Deploy
You can use the Deploy administration utility as part of the procedure to upgrade the VMware ESXi hypervisors hosting an ONTAP Select multi-node cluster.
About this task
You must perform this upgrade procedure for each of the nodes in the cluster, one node at a time. If the cluster contains four or more nodes, you should upgrade the nodes in each HA pair sequentially before proceeding to the next HA pair.
Steps
    Refer to Preparing to upgrade VMware ESXi for more information.
  5. After the node comes up, verify that storage failover is enabled and the cluster is healthy.
    Show example
    ESX-2N_I2_N11N12::> storage failover show
    Takeover
    Node Partner Possible State Description
    sdot-d200-011d sdot-d200-012d true Connected to sdot-d200-012d
    sdot-d200-012d sdot-d200-011d true Connected to sdot-d200-011d
    2 entries were displayed.
    ESX-2N_I2_N11N12::> cluster show
    sdot-d200-012d true true
After you finish
You must perform the upgrade procedure for each host used in the ONTAP Select cluster. After all the ESXi hosts are upgraded, you should perform a cluster refresh operation using the Deploy administration utility.
Upgrade a single-node cluster without Deploy
You can upgrade the VMware ESXi hypervisor hosting an ONTAP Select single-node cluster without using the Deploy administration utility.
Steps
  1. Sign in to the ONTAP command line interface and halt the node.
  2. Using VMware vSphere, confirm that the ONTAP Select virtual machine is powered off.
  4. Using VMware vSphere, access vCenter and do the following:
    1. Add a floppy drive to the ONTAP Select virtual machine.
    2. Power on the ONTAP Select virtual machine.
    3. Sign in to the ONTAP CLI using SSH with the administrator account.
    Example:
After you finish
Upgrade a multi-node cluster without Deploy
You can upgrade the VMware ESXi hypervisors hosting an ONTAP Select multi-node cluster without using the Deploy administration utility.
About this task
Steps
    Show example
    Takeover
After you finish
