Hyper-V storage requirements for ONTAP Select
When you configure ONTAP Select on a Hyper-V hypervisor, ONTAP Select stores the virtual machine (VM) and the virtual disks on a local volume on the Hyper-V host.
Basic requirements and restrictions
The following configuration requirements and restrictions apply to ONTAP Select storage pools on a Hyper-V host:
The storage pool must be an NTFS or ReFS volume with a drive letter assigned. The Deploy utility identifies the storage pool by its drive letter.
Cluster Shared Volumes are not supported as storage pools.
Network file shares and remote UNC paths, such as SMB 3.0, are not supported as storage pools.
ONTAP Select does not discover a volume that is mounted only to a folder path because the volume has no drive letter.
ONTAP Select can use a LUN on an external storage array using FC, FCoE, or iSCSI if the Hyper-V host formats the LUN as NTFS or ReFS and assigns a drive letter. ONTAP Select treats such a volume as local host storage. The ONTAP Select vNAS model used with ESXi does not apply to Hyper-V.
A Storage Spaces virtual disk can hold a storage pool if it is formatted as NTFS or ReFS with a drive letter assigned. However, software RAID cannot use physical disks that are members of a Storage Spaces pool.
A Hyper-V configuration does not recognize thinly provisioned storage. ONTAP Select uses the capacity that Windows reports for the volume.
Best practices
You should follow these best practices:
Define dedicated network adapters, bandwidth, and virtual switch configurations for the ONTAP Select networks. Keep external storage traffic, such as iSCSI, on separate adapters.
Dedicate the storage pool volume to ONTAP Select. Do not place another Hyper-V VM or Windows workload on the same volume, and do not use the Windows boot volume as a storage pool.
Size the volume so that ONTAP Select does not consume its entire capacity.
Configure Windows MPIO for external storage arrays so that LUNs are presented over redundant paths.
