ONTAP Select clusters
Contributors dmp-netapp
There are several related tasks you can perform to administer an ONTAP Select cluster.
Moving an ONTAP Select cluster to the offline and online states
After you have created a cluster, you can change its status to offline or online as needed.
Steps
  1. Click ONTAP Select Clusters in the Global Inventory Lists pane.
  2. Right click the desired cluster to display the available actions.
  3. Click Take Offline or Bring Online as appropriate and click Yes to confirm the request.
Deleting an ONTAP Select cluster
You can delete an ONTAP Select cluster when it is no longer needed.
Before you begin
The cluster must be in the offline state.
Steps
  3. Click Delete Cluster and click Yes to confirm the request.
    If the delete option is not available, then the cluster is not in an offline state.
