Update the HBA driver, firmware, and BIOS
If the FC host bus adapters (HBAs) in the ESX host are not running supported driver, firmware, and BIOS versions, you must update them.
Before you begin
You must have identified the supported driver, firmware, and BIOS versions for your configuration from the NetApp Interoperability Matrix Tool.
About this task
Drivers, firmware, BIOS, and HBA utilities are provided by the HBA vendors.
Steps
List the installed HBA driver, firmware, and BIOS versions using the ESXi host console commands for your version of ESXi.
Download and install the new driver, firmware, and BIOS as needed from the HBA vendor's support site.
Installation instructions and any required installation utilities are available with the download.
