Local UNIX users and groups with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to maintain a list of local UNIX users and groups for each storage virtual machine (SVM).
UNIX window
You can use the UNIX window to maintain a list of local UNIX users and groups for each storage virtual machine (SVM). You can use local UNIX users and groups for authentication and name mappings.
Groups tab
You can use the Groups tab to add, edit, or delete UNIX groups that are local to an SVM.
Command buttons
Add Group
Opens the Add Group dialog box, which enables you to create UNIX groups that are local to SVMs. Local UNIX groups are used with local UNIX users.
Edit
Opens the Edit Group dialog box, which enables you to edit a group ID.
Delete
Deletes the selected group.
Refresh
Updates the information in the window.
Groups list
Group Name
Displays the name of the group.
Group ID
Displays the ID of the group.
Users tab
You can use the Users tab to add, edit, and delete UNIX users that are local to SVMs.
Command buttons
Add User
Opens the Add User dialog box, which enables you to create UNIX users that are local to SVMs.
Edit
Opens the Edit User dialog box, which enables you to edit the User ID, UNIX group to which the user belongs, and the full name of the user.
Delete
Deletes the selected user.
Refresh
Users list
User Name
Displays the name of the user.
User ID
Displays the ID of the user.
Full Name
Displays the full name of the user.
Primary Group ID
Displays the ID of the group to which the user belongs.
Primary Group Name
Displays the name of the group to which the user belongs.
