Changing the status of a FlexCache volume
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
Your file is ready
Beginning with System Manager 9.6, you can change the status of a FlexCache volume when you want to take it offline, bring a FlexCache volume back online, or restrict access to a FlexCache volume.
Steps
Click Storage > Volumes.
From the drop-down menu in the SVM field, select All SVMs.
Select the FlexCache volume for which you want to modify the status.
Click More Actions > Change status to, and then update the FlexCache volume status by selecting the required status.
To take a FlexCache volume offline and to change the status to "restricted", you must first unmount the volume.
