Configure System Manager options - ONTAP 9.7 and earlier
You can enable logging and specify the inactivity timeout value for ONTAP System Manager classic (available in ONTAP 9.7 or earlier).
About this task
You can configure the options from the System Manager login window. However, you must log in to the application to specify the inactivity timeout value.
Steps
Click
In the Setup pane, click General.
Specify a log level.
Specify the inactivity timeout value in minutes.
This option is not available if you have enabled Security Assertion Markup Language (SAML) authentication.
Click OK.
