System Manager Classic
Create FlexClone volumes with System Manager - ONTAP 9.7 and earlier
Contributors netapp-mwallis
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to create a FlexClone volume when you require a writable, point-in-time copy of an existing FlexVol volume. You might want to create a copy of a volume for testing or to provide access to the volume for additional users without giving them access to the production data.
Before you begin
  • The FlexClone license must be installed on the storage system.
  • The volume that you want to clone must be online and must be a non-root volume.
About this task
The base Snapshot copy that is used to create a FlexClone volume of a SnapMirror destination is marked as busy and cannot be deleted. If a FlexClone volume is created from a Snapshot copy that is not the most recent Snapshot copy, and that Snapshot copy no longer exists on the source volume, all SnapMirror updates to the destination volume fail.
Steps
  1. Click Storage > Volumes.
  2. From the drop-down menu in the SVM field, select All SVMs.
  3. Select the FlexVol volume that you want to clone from the list of volumes.
  4. Click More Actions > Clone > Create > Volume.
  5. Type the name of the FlexClone volume that you want to create.
  6. Optional: If you want to enable thin provisioning for the new FlexClone volume, select Thin Provisioning.
    By default, this setting is the same as that of the parent volume.
  7. Create a Snapshot copy or select an existing Snapshot copy that you want to use as the base Snapshot copy for creating the FlexClone volume.
  8. Click Clone.
Related information
