Update NDMP backup after moving a volume
PDF of this doc site
Provision NAS storage
Provision SAN storage
Data protection and disaster recovery
Creating your file...
If the volume that you moved was previously backed up to tape using NDMP in a specific configuration, after moving the volume, you can perform one of the following actions to ensure the volume continues to be backed up successfully: create a baseline or migrate the backup LIF to the node containing the moved volume.
This procedure is necessary only if the backup application does not support the cluster-aware backup (CAB) extension and the backup process uses node-scoped NDMP.
If the backup application supports CAB and it is configured to use the SVM-scoped NDMP mode, you can skip this procedure.
You must perform only one of these actions, not both.
Procedure
From the backup application, create a new baseline.
Identify the LIF that is configured for the backup process, and then migrate the LIF to the node where the volume now resides.
