Components and part numbers for the Broadcom BES-53248 cluster switch
Identify the components and part numbers for the Broadcom BES-53248 cluster switch to support hardware installation and ongoing maintenance.
The following table lists the part number, description, and minimum EFOS and ONTAP versions for the BES-53248 cluster switch components, including rack-mount rail kit details.
A minimum EFOS version of 3.10.0.3 is required for part numbers X190005-B and X190005R-B. |
| Part number | Description | Minimum EFOS version | Minimum ONTAP version |
X190005-B |
BES-53248-B/IX8, CLSW, 16PT10/25GB, PTSX (PTSX = Port Side Exhaust) |
3.10.0.3 |
9.8 |
X190005R-B |
BES-53248-B/IX8, CLSW, 16PT10/25GB, PSIN (PSIN = Port Side Intake) |
3.10.0.3 |
9.8 |
X190005 |
BES-53248, CLSW, 16Pt10/25GB, PTSX, BRDCM SUPP |
3.4.4.6 |
9.5P8 |
X190005R |
BES-53248, CLSW, 16Pt10/25GB, PSIN, BRDCM SUPP |
3.4.4.6 |
9.5P8 |
X-RAIL-4POST-190005 |
Rack mount rail kit Ozeki 4 post 19" |
N/A |
N/A |
Note the following information with regards to machine types: |
| Machine type | Minimum EFOS version |
BES-53248A1 |
3.4.4.6 |
BES-53248A2 |
3.10.0.3 |
BES-53248A3 |
3.10.0.3 |
You can determine your specific machine type by using the command: show version
Show example
(cs1)# show version Switch: cs1 System Description............................. EFOS, 3.10.0.3, Linux 5.4.2-b4581018, 2016.05.00.07 Machine Type................................... BES-53248A3 Machine Model.................................. BES-53248 Serial Number.................................. QTWCU225xxxxx Part Number.................................... 1IX8BZxxxxx Maintenance Level.............................. a3a Manufacturer................................... QTMC Burned In MAC Address.......................... C0:18:50:F4:3x:xx Software Version............................... 3.10.0.3 Operating System............................... Linux 5.4.2-b4581018 Network Processing Device...................... BCM56873_A0 . . .
After you've confirmed your components and part numbers, you can review the required documentation.
