Install hardware for the Broadcom BES-53248 cluster switch
Install the Broadcom BES-53248 cluster switch hardware by following the Broadcom-supported BES-53248 Cluster Switch Installation Guide.
Steps
Review the configuration requirements.
Follow the instructions in the Broadcom-supported BES-53248 Cluster Switch Installation Guide.
What's next?
After you've installed the hardware for the switch, you can review cabling and configuration requirements.
