Install and maintain
Install or upgrade NX-OS software on Cisco Nexus 3232C storage switches
Contributors netapp-yvonneo netapp-jsnyder
Install or upgrade the NX-OS software on Cisco Nexus 3232C storage switches to prepare them for storage network operation.
Note NetApp recommends that you complete any ONTAP software upgrade first, then perform the software upgrade for your switches.
Before you begin
Verify that you have the following:
  • A current backup of the switch configuration.
  • A fully functioning cluster (no errors in the logs or similar issues).
  • Cisco Ethernet switch page. Consult the switch compatibility table for the supported ONTAP and NX-OS versions.
  • Cisco Nexus 3000 Series Switches. Refer to the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures.
Install or upgrade the software
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
Complete the procedure in Prepare to install NX-OS and RCF, and then follow the steps below.
Steps
  1. Connect the switch to the management network.
  2. Use the ping command to verify connectivity to the server hosting the NX-OS software and the RCF.
    Show example
    This example verifies that the switch can reach the server at IP address 172.19.2.1:
    s2# ping 172.19.2.1
    Pinging 172.19.2.1 with 0 bytes of data:
    Reply From 172.19.2.1: icmp_seq = 0. time= 5910 usec.
  3. If you are setting up your switch for the first time, skip to step 5. If you are upgrading your switch, proceed to the next step.
  4. Check the administrative or operational status of each node storage port and storage shelf port.
    1. Display the node storage port attributes:
      storage port show
      Show example
      cluster1::*> storage port show
      Speed                     VLAN
      Node           Port Type  Mode    (Gb/s) State    Status      ID
      cluster1-01
                     e5a  ENET  storage    100 enabled  online      -
                     e3b  ENET  storage    100 enabled  online      -
      cluster1-02
    2. Display the storage shelf port attributes:
      storage shelf port show
      Show example
      cluster1::*> storage shelf port show
      Shelf ID Module State        Internal?
      1.4
             0 A      connected    false
             1 A      connected    false
             2 B      connected    false
             3 B      connected    false
    3. Verify that switch health monitoring (CSHM) is enabled for the switches so that they are monitored:
      system switch ethernet show
      Show example
      cluster1::> system switch ethernet show
        Switch            Type               Address          Model
        s1                storage-network    1.0.0.0          N3K-C3232C
           Serial Number: FFFYYYYYYY1
            Is Monitored: true
                  Reason: None
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          10.3(4a)
          Version Source: CDP/ISDP
        s2                storage-network    1.1.0.0           N3K-C3232C
           Serial Number: FEEYYYYYYY2
            Is Monitored: true
                  Reason: None
                          10.3(4a)
  5. Log in to the switch using SSH or by using a serial console.
  6. Copy the NX-OS software and EPLD images to the Nexus 3232C switch.
    Show example
    s2# copy sftp: bootflash: vrf management
    Enter source filename: /code/nxos.9.3.4.bin
    Enter hostname for the sftp server: 172.19.2.1
    Enter username: user1
    Outbound-ReKey for 172.19.2.1:22
    Inbound-ReKey for 172.19.2.1:22
    user1@172.19.2.1's password:
    sftp> progress
    Progress meter enabled
    sftp> get   /code/nxos.9.3.4.bin  /bootflash/nxos.9.3.4.bin
    /code/nxos.9.3.4.bin  100% 1261MB   9.3MB/s   02:15
    sftp> exit
    Copy complete, now saving to disk (please wait)...
    Copy complete.
    Enter source filename: /code/n9000-epld.9.3.4.img
    sftp> progress
    sftp> get   /code/n9000-epld.9.3.4.img  /bootflash/n9000-epld.9.3.4.img
    /code/n9000-epld.9.3.4.img  100%  161MB   9.5MB/s   00:16
    sftp> exit
    Copy complete.
  7. Verify the running version of the NX-OS software:
    show version
    Show example
    s2# show version
    TAC support: http://www.cisco.com/tac
    Copyright (C) 2002-2019, Cisco and/or its affiliates.
    All rights reserved.
    The copyrights to certain works contained in this software are
    owned by other third parties and used and distributed under their own
    licenses, such as open source.  This software is provided "as is," and unless
    otherwise stated, there is no warranty, express or implied, including but not
    limited to warranties of merchantability and fitness for a particular purpose.
    Certain components of this software are licensed under
    the GNU General Public License (GPL) version 2.0 or
    GNU General Public License (GPL) version 3.0  or the GNU
    Lesser General Public License (LGPL) Version 2.1 or
    Lesser General Public License (LGPL) Version 2.0.
    A copy of each such license is available at
    http://www.opensource.org/licenses/gpl-2.0.php and
    http://opensource.org/licenses/gpl-3.0.html and
    http://www.opensource.org/licenses/lgpl-2.1.php and
    http://www.gnu.org/licenses/old-licenses/library.txt.
    Software
      BIOS: version 08.37
      NXOS: version 9.3(3)
      BIOS compile time:  01/28/2020
      NXOS image file is: bootflash:///nxos.9.3.3.bin
      NXOS compile time:  12/22/2019 2:00:00 [12/22/2019 14:00:37]
    Hardware
      cisco Nexus3000 C3232C Chassis (Nexus 9000 Series)
      Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 8154432 kB of memory.
      Processor Board ID FOCXXXXXXGD
      Device name: s2
      bootflash:   53298520 kB
    Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 36 second(s)
    Last reset at 74117 usecs after Tue Nov 24 06:24:23 2020
      Reason: Reset Requested by CLI command reload
      System version: 9.3(3)
      Service:
    plugin
      Core Plugin, Ethernet Plugin
    Active Package(s):
  8. Install the NX-OS image.
    Installing the image file causes it to be loaded every time the switch is rebooted.
    Show example
    s2# install all nxos bootflash:nxos.9.3.4.bin
    Installer will perform compatibility check first. Please wait.
    Installer is forced disruptive
    Verifying image bootflash:/nxos.9.3.4.bin for boot variable "nxos".
    [] 100% -- SUCCESS
    Verifying image type.
    [] 100% -- SUCCESS
    Preparing "nxos" version info using image bootflash:/nxos.9.3.4.bin.
    [] 100% -- SUCCESS
    Preparing "bios" version info using image bootflash:/nxos.9.3.4.bin.
    [] 100% -- SUCCESS
    Performing module support checks.
    [] 100% -- SUCCESS
    Notifying services about system upgrade.
    [] 100% -- SUCCESS
    Compatibility check is done:
    Module  bootable          Impact              Install-type  Reason
         1     Yes            Disruptive          Reset         Default upgrade is not hitless
    Images will be upgraded according to following table:
    Module       Image       Running-Version(pri:alt)                New-Version          Upg-Required
         1       nxos        9.3(3)                                  9.3(4)               yes
         1       bios        v08.37(01/28/2020):v08.32(10/18/2016)   v08.37(01/28/2020)   no
    Switch will be reloaded for disruptive upgrade.
    Do you want to continue with the installation (y/n)?  [n] y
    Install is in progress, please wait.
    Performing runtime checks.
    [] 100% -- SUCCESS
    Setting boot variables.
    [] 100% -- SUCCESS
    Performing configuration copy.
    [] 100% -- SUCCESS
    Module 1: Refreshing compact flash and upgrading bios/loader/bootrom.
    Warning: please do not remove or power off the module at this time.
    [] 100% -- SUCCESS
    Finishing the upgrade, switch will reboot in 10 seconds.
  9. Verify the new version of NX-OS software after the switch has rebooted:
    show version
    Show example
    s2# show version
    Copyright (C) 2002-2020, Cisco and/or its affiliates.
    Software
      BIOS: version 08.37
      NXOS: version 9.3(4)
      NXOS image file is: bootflash:///nxos.9.3.4.bin
      NXOS compile time:  4/28/2020 21:00:00 [04/29/2020 06:28:31]
    Hardware
      Processor Board ID FOCXXXXXXGS
      Device name: rtpnpi-mcc01-8200-ms-A1
    Kernel uptime is 0 day(s), 0 hour(s), 3 minute(s), 14 second(s)
    Last reset at 196755 usecs after Tue Nov 24 06:37:36 2020
      Reason: Reset due to upgrade
      Service:
    plugin
    Active Package(s):
  10. Upgrade the EPLD image and reboot the switch.
    Show example
    s2# show version module 1 epld
    EPLD Device                     Version
    MI   FPGA                       0x12
    IO   FPGA                       0x11
    s2# install epld bootflash:n9000-epld.9.3.4.img module 1
    Compatibility check:
    Module        Type         Upgradable    Impact      Reason
         1         SUP         Yes           Disruptive  Module Upgradable
    Retrieving EPLD versions.... Please wait.
    Module  Type   EPLD              Running-Version   New-Version  Upg-Required
         1   SUP   MI FPGA                0x12         0x12         No
         1   SUP   IO FPGA                0x11         0x12         Yes
    The above modules require upgrade.
    The switch will be reloaded at the end of the upgrade
    Do you want to continue (y/n) ?  [n] y
    Proceeding to upgrade Modules.
    Starting Module 1 EPLD Upgrade
    Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sectors)
    Module 1 EPLD upgrade is successful.
    Module        Type  Upgrade-Result
         1         SUP         Success
  11. If you are upgrading to NX-OS version 9.3(11), you must upgrade the EPLD golden image and reboot the switch once again. Otherwise, skip to step 12.
    Show example
    s2# install epld bootflash:n9000-epld.9.3.11.img module 1 golden
    Digital signature verification is successful
    Module 1 : MI FPGA [Programming] : 100.00% (     64 of      64 sect)
    Module 1 : IO FPGA [Programming] : 100.00% (     64 of      64 sect)
         1         SUP          Success
    EPLDs upgraded.
  12. After the switch reboot, log in to verify that the new version of EPLD loaded successfully.
    Show example
    EPLD Device                     Version
    MI   FPGA                        0x12
    IO   FPGA                        0x12
  13. If you are setting up your switch for the first time, skip to step 15. If you are upgrading your switch, proceed to the next step.
  14. Verify the health status of each node storage port and storage shelf port.
      storage port show
      Show example
      Speed                     VLAN
      cluster1-01
      cluster1-02
      Show example
      1.4
             0 A      connected    false
             1 A      connected    false
             2 B      connected    false
             3 B      connected    false
      Show example
            Is Monitored: true
                  Reason: None
                          10.3(4a)
            Is Monitored: true
                  Reason: None
                          10.3(4a)
          Version Source: CDP/ISDP  false
  15. Repeat steps 5 to 13 to install the NX-OS software on switch s1.
What's next?
After you've installed the NX-OS software, you can install or upgrade the Reference Configuration File (RCF).
