Install and maintain
Complete the migration from a two-node switchless cluster to Cisco Nexus 3232C cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Complete the final steps to migrate from a two-node switchless cluster to a two-node switched cluster using Cisco Nexus 3232C cluster switches.
Steps
  1. Verify that all of the cluster interconnect ports are now reverted to their home ports:
    network interface show -role cluster
    The Is Home column should display a value of true for all of the ports listed in the Current Port column. If the displayed value is false, the port has not been reverted.
    Show example
    cluster::*> network interface show -role cluster
     (network interface show)
                Logical    Status     Network            Current       Current Is
    Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
    Cluster
                n1_clus1   up/up      10.10.0.1/24       n1            e4a     true
                n1_clus2   up/up      10.10.0.2/24       n1            e4e     true
                n2_clus1   up/up      10.10.0.3/24       n2            e4a     true
                n2_clus2   up/up      10.10.0.4/24       n2            e4e     true
    4 entries were displayed.
  2. Verify that all of the cluster interconnect ports are in the up state:
    network port show -role cluster
  3. Display the cluster switch port numbers through which each cluster port is connected to each node:
    network device-discovery show
    Show example
    cluster::*> network device-discovery show
                Local  Discovered
    Node        Port   Device              Interface        Platform
    n1          /cdp
                e4a    C1                  Ethernet1/7      N3K-C3232C
                e4e    C2                  Ethernet1/7      N3K-C3232C
    n2          /cdp
                e4a    C1                  Ethernet1/8      N3K-C3232C
                e4e    C2                  Ethernet1/8      N3K-C3232C
  4. Display discovered and monitored cluster switches:
    system cluster-switch show
    Show example
    cluster::*> system cluster-switch show
    Switch                      Type               Address          Model
    C1                          cluster-network    10.10.1.101      NX3232CV
    Serial Number: FOX000001
    Is Monitored: true
    Reason:
    Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 7.0(3)I6(1)
    Version Source: CDP
    C2                          cluster-network     10.10.1.102      NX3232CV
    Serial Number: FOX000002
    Is Monitored: true
    Reason:
    Version Source: CDP 2 entries were displayed.
  5. Verify that switchless cluster detection changed the switchless cluster option to disabled:
    network options switchless-cluster show
  6. Verify the connectivity of the remote cluster interfaces:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source           Destination      Packet
Node   Date                       LIF              LIF              Loss
n1
       3/5/2022 19:21:18 -06:00   n1_clus2         n2-clus1         none
       3/5/2022 19:21:20 -06:00   n1_clus2         n2_clus2         none
n2
       3/5/2022 19:21:18 -06:00   n2_clus2         n1_clus1         none
       3/5/2022 19:21:20 -06:00   n2_clus2         n1_clus2         none
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is n1
Getting addresses from network interface table...
Cluster n1_clus1 n1        e4a    10.10.0.1
Cluster n1_clus2 n1        e4e    10.10.0.2
Cluster n2_clus1 n2        e4a    10.10.0.3
Cluster n2_clus2 n2        e4e    10.10.0.4
Local = 10.10.0.1 10.10.0.2
Remote = 10.10.0.3 10.10.0.4
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s) ................
Detected 9000 byte MTU on 32 path(s):
    Local 10.10.0.1 to Remote 10.10.0.3
    Local 10.10.0.1 to Remote 10.10.0.4
    Local 10.10.0.2 to Remote 10.10.0.3
    Local 10.10.0.2 to Remote 10.10.0.4
Larger than PMTU communication succeeds on 4 path(s) RPC status:
1 paths up, 0 paths down (tcp check)
1 paths up, 0 paths down (ucp check)
  1. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
What's next?
After you've completed your switch migration, you can configure switch health monitoring.
