Install and maintain
Reset the Cisco Nexus 3232C cluster switch to factory defaults
Contributors netapp-yvonneo netapp-jsnyder
Reset the Cisco Nexus 3232C cluster switch to factory defaults by erasing the current switch configuration and restoring the switch to its original settings.
About this task
  • You must be connected to the switch using the serial console.
  • This task resets the configuration of the management network.
Steps
  1. Erase the existing configuration:
    write erase
    (cs2)# write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  2. Reload the switch software:
    reload
    (cs2)# reload
    This command will reboot the system. (y/n)? [n] y
    The system reboots and enters the configuration wizard. During the boot, if you receive the prompt “Abort Auto Provisioning and continue with normal setup? (yes/no)[n]”, you should respond yes to proceed.
What's next
After resetting the switch, you can reconfigure it according to your requirements.
