Hardware installation workflow for Cisco Nexus 92300YC cluster switches
Follow this workflow to install and configure the hardware for Cisco Nexus 92300YC cluster switches.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
Install the 92300YC switch.
Install the 92300YC switch and pass-through panel in a NetApp cabinet as required.
Review support for NVIDIA Ethernet ports.
