Review cabling and configuration considerations
Before configuring your Cisco 9332D-GX2B switch, review the following considerations.
Support for NVIDIA CX6-DX Ethernet ports
If connecting a switch port to an ONTAP controller using NVIDIA ConnectX-6 Dx (CX6-DX) NIC ports (part number X50130B), you must hard-code the switch port speed.
(cs1)# configure (cs1)(config)# interface Ethernet1/16/? (cs1)(config-if)# speed 100000 (cs1)(config-if)# no negotiate auto (cs1)(config-if)# exit (cs1)(config)# exit (cs1)# copy running-config startup-config
See the Hardware Universe for more information on switch ports. See What additional information do I need to install my equipment that is not in HWU? for more information about switch installation requirements.
