Install and maintain
Network requirements for Cisco Nexus 9332D-GX2B switches
Contributors netapp-yvonneo
For Cisco Nexus 9332D-GX2B switch installation and maintenance, be sure to review cabling and network requirements.
You need the following network information for all switch configurations.
Cabling requirements
  • You have the appropriate number and type of cables and cable connectors for your switches. See the Hardware Universe.
  • Depending on the type of switch you are initially configuring, you need to connect to the switch console port with the included console cable.
