Review cabling and configuration requirements for the Cisco Nexus 9332D-GX2B switch
Review the cabling and configuration requirements for Cisco Nexus 9332D-GX2B switches before installing them as part of a new AFX 1K or AFX 2K system, replacing a switch, or resetting a switch to factory default settings.
Hard-code the speed on breakout ports
You must hard-code the switch breakout (4x100GbE) ports for 100GbE. If you do not hard-code the speed, the ports will not come up and will be in an error-disabled state.
For example, to hard-code 100GbE on breakout ports 1-14, do the following in config mode. The example shows commands being applied to the first switch (cs1). You repeat these commands for the second switch.
(cs1)(config)# interface e1/1/1-4, e1/2/1-4, e1/3/1-4, e1/4/1-4, e1/5/1-4, e1/6/1-4, e1/7/1-4, e1/8/1-4, e1/9/1-4, e1/10/1-4, e1/11/1-4, e1/12/1-4, e1/13/1-4, e1/14/1-4 (cs1)(config-if)# speed 100000 (cs1)(config-if)# no negotiate auto (cs1)(config-if)# exit (cs1)(config)# exit (cs1)# copy running-config startup-config
What's next?
After you meet the cabling and configuration requirements, you install the NX-OS.
