Install and maintain
Documentation requirements for Cisco Nexus 9332D-GX2B switches
Contributors netapp-yvonneo
For Cisco Nexus 9332D-GX2B switch installation, be sure to review specific switch and controller documentation to set up your 9332D-GX2B switches and ONTAP cluster.
Switch documentation
To set up the Cisco Nexus 9332D-GX2B switches, you need the following documentation from Cisco Nexus 9000 Series Switches Support.
Document title Description
Provides detailed information about site requirements, switch hardware details, and installation options.
Cisco Nexus 9000 Series Switch Software Configuration Guides (choose the guide for the NX-OS release installed on your switches)
Provides initial switch configuration information that you need before you can configure the switch for ONTAP operation.
Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide (choose the guide for the NX-OS release installed on your switches)
Provides information on how to downgrade the switch to ONTAP supported switch software, if necessary.
Provides links to the various command references provided by Cisco.
Describes the system messages for Cisco Nexus 9000 series switches, those that are informational, and others that might help diagnose problems with links, internal hardware, or the system software.
Cisco Nexus 9000 Series NX-OS Release Notes (choose the notes for the NX-OS release installed on your switches)
Describes the features, bugs, and limitations for the Cisco Nexus 9000 Series.
Provides international agency compliance, safety, and statutory information for the Nexus 9000 series switches.
ONTAP systems documentation
To set up an ONTAP system, you need the following documents for your version of the operating system.
Name Description
Describes how to install NetApp hardware.
Provides detailed information about all aspects of the ONTAP releases.
Provides NetApp hardware configuration and compatibility information.
