Hardware installation workflow for Cisco Nexus 9336C-FX2 shared switches
Follow this workflow to install and configure the hardware for a Cisco Nexus 9336C-FX2 shared switch.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
Install the 9336C-FX2 switch.
Install the 9336C-FX2 switch and pass-through panel in a NetApp cabinet as required.
