Install Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Install Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches to provide front-end storage connectivity for ONTAP systems.
Make sure you have the following:
Access to an HTTP, FTP or TFTP server at the installation site to download the applicable NX-OS and reference configuration file (RCF) releases.
Applicable NX-OS version, downloaded from the Cisco Software Download page.
Applicable licenses, network and configuration information, and cables.
Completed cabling worksheets.
Applicable NetApp storage network and management network RCFs downloaded from the NetApp Support Site at mysupport.netapp.com.
All Cisco storage network and management network switches arrive with the standard Cisco factory-default configuration. These switches also have the current version of the NX-OS software but do not have the RCFs loaded.
Required switch documentation. Refer to Required documentation for more information.
Rack the network and management network switches and controllers.
If you are installing your… Then… Cisco Nexus 9336C-FX2 in a NetApp system cabinet
Refer to Install switch in NetApp cabinet for instructions to install the switch in a NetApp cabinet.
Equipment in a Telco rack
Refer to the procedures provided in the switch hardware installation guides and the NetApp installation and setup instructions.
Cable the network and management network switches to the controllers using the completed cabling worksheets.
Power on the network and management network switches and controllers.
Optionally, you can install a Cisco Nexus 9336C-FX2 switch in a NetApp cabinet. Otherwise, go to configure the switch.
