Install and maintain
Complete the Cisco Nexus 9336C-FX2 or 9336C-FX2-T cabling worksheet
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder netapp-lisa
Complete the cabling worksheet for Cisco Nexus 9336C-FX2 or 9336C-FX2-T storage switches to document port connections and supported platform configurations.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
9336C-FX2 sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
4x100GbE node 1
1
4x100GbE node 1
2
4x100GbE node 2
2
4x100GbE node 2
3
4x100GbE node 3
3
4x100GbE node 3
4
4x100GbE node 4
4
4x100GbE node 4
5
4x100GbE node 5
5
4x100GbE node 5
6
4x100GbE node 6
6
4x100GbE node 6
7
4x100GbE node 7
7
4x100GbE node 7
8
4x100GbE node 8
8
4x100GbE node 8
9
4x100GbE node 9
9
4x100GbE node 9
10
4x100GbE node 10
10
4x100GbE node 10
11
4x100GbE node 11
11
4x100GbE node 11
12
4x100GbE node 12
12
4x100GbE node 12
13
4x100GbE node 13
13
4x100GbE node 13
14
4x100GbE node 14
14
4x100GbE node 14
15
4x100GbE node 15
15
4x100GbE node 15
16
4x100GbE node 16
16
4x100GbE node 16
17
4x100GbE node 17
17
4x100GbE node 17
18
4x100GbE node 18
18
4x100GbE node 18
19
4x100GbE node 19
19
4x100GbE node 19
20
4x100GbE node 20
20
4x100GbE node 20
21
4x100GbE node 21
21
4x100GbE node 21
22
4x100GbE node 22
22
4x100GbE node 22
23
4x100GbE node 23
23
4x100GbE node 23
24
4x100GbE node 24
24
4x100GbE node 24
25
4x100GbE node 25
25
4x100GbE node 25
26
4x100GbE node 26
26
4x100GbE node 26
27
4x100GbE node 27
27
4x100GbE node 27
28
4x100GbE node 28
28
4x100GbE node 28
29
4x100GbE node 29
29
4x100GbE node 29
30
4x100GbE node 30
30
4x100GbE node 30
31
4x100GbE node 31
31
4x100GbE node 31
32
4x100GbE node 32
32
4x100GbE node 32
33
4x100GbE node 33
33
4x100GbE node 33
30
4x100GbE node 30
30
4x100GbE node 33
34
4x100GbE node 34
34
4x100GbE node 34
35
4x100GbE node 35
35
4x100GbE node 35
36
4x100GbE node 36
36
4x100GbE node 36
9336C-FX2 blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25
25
26
26
27
27
28
28
29
29
30
30
31
31
32
32
33
33
34
34
35
35
36
36
9336C-FX2-T sample cabling worksheet (12-port)
Switch port
Node and port usage
Switch port
Node and port usage
1
4x100GbE node 1
1
4x100GbE node 1
2
4x100GbE node 2
2
4x100GbE node 2
3
4x100GbE node 3
3
4x100GbE node 3
4
4x100GbE node 4
4
4x100GbE node 4
5
4x100GbE node 5
5
4x100GbE node 5
6
4x100GbE node 6
6
4x100GbE node 6
7
4x100GbE node 7
7
4x100GbE node 7
8
4x100GbE node 8
8
4x100GbE node 8
9
4x100GbE node 9
9
4x100GbE node 9
10
4x100GbE node 10
10
4x100GbE node 10
11 though 36
Requires license
11 through 36
Requires license
9336C-FX2-T blank cabling worksheet (12-port)
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11 through 36
Requires license
11 through 36
Requires license
Refer to the Hardware Universe for more information on switch ports.
What's next
After you've completed your cabling worksheets, you can install the switch.
