Install and maintain
Install the RCF on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches
Contributors netapp-yvonneo netapp-jsnyder
Install the reference configuration file (RCF) on Cisco Nexus 9336C-FX2 and 9336C-FX2-T storage switches after initial setup. The RCF defines port assignments and network settings required for storage network operation.
Refer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further information when installing your RCF.
Before you begin
Verify the following installations and connections:
  • A console connection to the switch. The console connection is optional if you have remote access to the switch.
  • Switch s1 and switch s2 are powered up and the initial switch setup is complete (the Management IP address and SSH is set up).
  • The desired NX-OS version has been installed.
  • ONTAP node storage ports and storage shelf ports are not connected.
Step 1: Install the RCF on the switches
  1. Log in to switch s2 using SSH or by using a serial console.
  2. Copy the RCF to the bootflash of switch s2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
    For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference.
    Show example
    This example shows TFTP being used to copy an RCF to the bootflash on switch s2:
    s2# copy tftp: bootflash: vrf management
    Enter source filename: NX9336C-FX2-RCF-v1.13-1-Storage.txt
    Enter hostname for the tftp server: 172.22.201.50
    Trying to connect to tftp server......Connection to Server Established.
    TFTP get operation was successful
    Copy complete, now saving to disk (please wait)...
  3. Apply the RCF previously downloaded to the bootflash.
    Show example
    This example shows the RCF NX9336C-FX2-RCF-v1.13-1-Storage.txt being installed on switch s2:
    s2# copy NX9336C-FX2-RCF-v1.13-1-Storage.txt running-config echo-commands
  4. Examine the banner output from the show banner motd command. You must read and follow these instructions to ensure the correct configuration and operation of the switch.
    Show example
    s2# show banner motd
    * NetApp Reference Configuration File (RCF)
    * Switch    : NX9336C-FX2
    * Filename  : NX9336C-FX2-RCF-v1.13-1-Storage.txt
    * Date      : 05-22-2025
    * Version   : v1.13
    * Port Usage : Storage configuration
    * Ports  1-36: 100GbE Controller and Shelf Storage Ports
    * IMPORTANT NOTES
    * Interface port-channel999 is reserved to identify the version of this file.
  5. Verify that the RCF is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  6. Record any custom additions between the current running-config file and the RCF file in use.
  7. After you verify that the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
    s2# copy running-config startup-config [########################################] 100% Copy complete
  8. Reboot switch s2.
    s2# reload
    This command will reboot the system. (y/n)? [n] y
  9. Repeat steps 1 through 8 on switch s1.
  10. Connect the node storage ports and storage shelf ports of all the nodes in the ONTAP cluster to switches s1 and s2.
Step 2: Verify the switch connections
  1. Verify that the switch ports are up.
    show interface brief
    Show example
    s1# show interface brief | grep up
    mgmt0  --           up     <mgmt ip address>                       1000    1500
    Eth1/11         1       eth  trunk  up      none                     100G(D) --
    Eth1/12         1       eth  trunk  up      none                     100G(D) --
    Eth1/13         1       eth  trunk  up      none                     100G(D) --
    Eth1/14         1       eth  trunk  up      none                     100G(D) --
    Eth1/15         1       eth  trunk  up      none                     100G(D) --
    Eth1/16         1       eth  trunk  up      none                     100G(D) --
    Eth1/17         1       eth  trunk  up      none                     100G(D) --
    Eth1/18         1       eth  trunk  up      none                     100G(D) --
    Eth1/23         1       eth  trunk  up      none                     100G(D) --
    Eth1/24         1       eth  trunk  up      none                     100G(D) --
    Eth1/25         1       eth  trunk  up      none                     100G(D) --
    Eth1/26         1       eth  trunk  up      none                     100G(D) --
    Eth1/27         1       eth  trunk  up      none                     100G(D) --
    Eth1/28         1       eth  trunk  up      none                     100G(D) --
    Eth1/29         1       eth  trunk  up      none                     100G(D) --
    Eth1/30         1       eth  trunk  up      none                     100G(D) --
  2. Verify that the node storage ports and storage shelf ports are in their correct VLANs using the following commands:
    show vlan brief
    show interface trunk
    Show example
    s1# show vlan brief
    VLAN Name                             Status    Ports
    1    default                          active    Po999
    30   VLAN0030                         active    Eth1/1, Eth1/2, Eth1/3, Eth1/4
                                                    Eth1/5, Eth1/6, Eth1/7, Eth1/8
                                                    Eth1/9, Eth1/10, Eth1/11
                                                    Eth1/12, Eth1/13, Eth1/14
                                                    Eth1/15, Eth1/16, Eth1/17
                                                    Eth1/18, Eth1/19, Eth1/20
                                                    Eth1/21, Eth1/22, Eth1/23
                                                    Eth1/24, Eth1/25, Eth1/26
                                                    Eth1/27, Eth1/28, Eth1/29
                                                    Eth1/30, Eth1/31, Eth1/32
                                                    Eth1/33, Eth1/34, Eth1/35
                                                    Eth1/36
    s1# show interface trunk
    Port          Native  Status        Port
                  Vlan                  Channel
    Eth1/1        1       trunking      --
    Eth1/2        1       trunking      --
    Eth1/3        1       trunking      --
    Eth1/4        1       trunking      --
    Eth1/5        1       trunking      --
    Eth1/6        1       trunking      --
    Eth1/7        1       trunking      --
    Eth1/8        1       trunking      --
    Eth1/9        1       trunking      --
    Eth1/10       1       trunking      --
    Eth1/11       1       trunking      --
    Eth1/12       1       trunking      --
    Eth1/13       1       trunking      --
    Eth1/14       1       trunking      --
    Eth1/15       1       trunking      --
    Eth1/16       1       trunking      --
    Eth1/17       1       trunking      --
    Eth1/18       1       trunking      --
    Eth1/19       1       trunking      --
    Eth1/20       1       trunking      --
    Eth1/21       1       trunking      --
    Eth1/22       1       trunking      --
    Eth1/23       1       trunking      --
    Eth1/24       1       trunking      --
    Eth1/25       1       trunking      --
    Eth1/26       1       trunking      --
    Eth1/27       1       trunking      --
    Eth1/28       1       trunking      --
    Eth1/29       1       trunking      --
    Eth1/30       1       trunking      --
    Eth1/31       1       trunking      --
    Eth1/32       1       trunking      --
    Eth1/33       1       trunking      --
    Eth1/34       1       trunking      --
    Eth1/35       1       trunking      --
    Eth1/36       1       trunking      --
    Port          Vlans Allowed on Trunk
    Eth1/1        30
    Eth1/2        30
    Eth1/3        30
    Eth1/4        30
    Eth1/5        30
    Eth1/6        30
    Eth1/7        30
    Eth1/8        30
    Eth1/9        30
    Eth1/10       30
    Eth1/11       30
    Eth1/12       30
    Eth1/13       30
    Eth1/14       30
    Eth1/15       30
    Eth1/16       30
    Eth1/17       30
    Eth1/18       30
    Eth1/19       30
    Eth1/20       30
    Eth1/21       30
    Eth1/22       30
    Eth1/23       30
    Eth1/24       30
    Eth1/25       30
    Eth1/26       30
    Eth1/27       30
    Eth1/28       30
    Eth1/29       30
    Eth1/30       30
    Eth1/31       30
    Eth1/32       30
    Eth1/33       30
    Eth1/34       30
    Eth1/35       30
    Eth1/36       30
    Port          Vlans Err-disabled on Trunk
    Eth1/1        none
    Eth1/2        none
    Eth1/3        none
    Eth1/4        none
    Eth1/5        none
    Eth1/6        none
    Eth1/7        none
    Eth1/8        none
    Eth1/9        none
    Eth1/10       none
    Eth1/11       none
    Eth1/12       none
    Eth1/13       none
    Eth1/14       none
    Eth1/15       none
    Eth1/16       none
    Eth1/17       none
    Eth1/18       none
    Eth1/19       none
    Eth1/20       none
    Eth1/21       none
    Eth1/22       none
    Eth1/23       none
    Eth1/24       none
    Eth1/25       none
    Eth1/26       none
    Eth1/27       none
    Eth1/28       none
    Eth1/29       none
    Eth1/30       none
    Eth1/31       none
    Eth1/32       none
    Eth1/33       none
    Eth1/34       none
    Eth1/35       none
    Eth1/36       none
    Port          STP Forwarding
    Eth1/1        none
    Eth1/2        none
    Eth1/3        none
    Eth1/4        none
    Eth1/5        none
    Eth1/6        none
    Eth1/7        none
    Eth1/8        none
    Eth1/9        none
    Eth1/10       none
    Eth1/11       30
    Eth1/12       30
    Eth1/13       30
    Eth1/14       30
    Eth1/15       30
    Eth1/16       30
    Eth1/17       30
    Eth1/18       30
    Eth1/19       none
    Eth1/20       none
    Eth1/21       none
    Eth1/22       none
    Eth1/23       30
    Eth1/24       30
    Eth1/25       30
    Eth1/26       30
    Eth1/27       30
    Eth1/28       30
    Eth1/29       30
    Eth1/30       30
    Eth1/31       none
    Eth1/32       none
    Eth1/33       none
    Eth1/34       none
    Eth1/35       none
    Eth1/36       none
    Port          Vlans in spanning tree forwarding state and not pruned
    Eth1/1        Feature VTP is not enabled
    none
    Eth1/2        Feature VTP is not enabled
    none
    Eth1/3        Feature VTP is not enabled
    none
    Eth1/4        Feature VTP is not enabled
    none
    Eth1/5        Feature VTP is not enabled
    none
    Eth1/6        Feature VTP is not enabled
    none
    Eth1/7        Feature VTP is not enabled
    none
    Eth1/8        Feature VTP is not enabled
    none
    Eth1/9        Feature VTP is not enabled
    none
    Eth1/10       Feature VTP is not enabled
    none
    Eth1/11       Feature VTP is not enabled
    30
    Eth1/12       Feature VTP is not enabled
    30
    Eth1/13       Feature VTP is not enabled
    30
    Eth1/14       Feature VTP is not enabled
    30
    Eth1/15       Feature VTP is not enabled
    30
    Eth1/16       Feature VTP is not enabled
    30
    Eth1/17       Feature VTP is not enabled
    30
    Eth1/18       Feature VTP is not enabled
    30
    Eth1/19       Feature VTP is not enabled
    none
    Eth1/20       Feature VTP is not enabled
    none
    Eth1/21       Feature VTP is not enabled
    none
    Eth1/22       Feature VTP is not enabled
    none
    Eth1/23       Feature VTP is not enabled
    30
    Eth1/24       Feature VTP is not enabled
    30
    Eth1/25       Feature VTP is not enabled
    30
    Eth1/26       Feature VTP is not enabled
    30
    Eth1/27       Feature VTP is not enabled
    30
    Eth1/28       Feature VTP is not enabled
    30
    Eth1/29       Feature VTP is not enabled
    30
    Eth1/30       Feature VTP is not enabled
    30
    Eth1/31       Feature VTP is not enabled
    none
    Eth1/32       Feature VTP is not enabled
    none
    Eth1/33       Feature VTP is not enabled
    none
    Eth1/34       Feature VTP is not enabled
    none
    Eth1/35       Feature VTP is not enabled
    none
    Eth1/36       Feature VTP is not enabled
    none
    Note For specific port and VLAN usage details, refer to the banner and important notes section in your RCF.
Step 3: Set up your ONTAP cluster
NetApp recommends that you use System Manager to set up new clusters.
System Manager provides a simple and easy workflow for cluster setup and configuration including assigning a node management IP address, initializing the cluster, creating a local tier, configuring protocols and provisioning initial storage.
What's next?
After you've installed your RCF, you can verify the SSH configuration
