Learn about installing or upgrading NX-OS on the Cisco Nexus 9364D-GX2A switch
Install or upgrade the NX-OS on Cisco Nexus 9364D-GX2A switches for AFX 1K and AFX 2K systems.
NX-OS installation or upgrade is independent of RCF installation or upgrade. If you are installing or upgrading both the NX-OS and RCF, it is recommended you install or upgrade NX-OS first. |
You install the NX-OS on the switches as part of a new AFX 1K or AFX 2K system installation, a switch replacement, or a switch reset to factory default settings.
You upgrade the NX-OS on the switches to support new hardware or a new ONTAP version on your AFX 1K or AFX 2K system.
