Network requirements for Cisco Nexus 9364D-GX2A switches
For Cisco Nexus 9364D-GX2A switch installation and maintenance, be sure to review cabling and network requirements.
You need the following network information for all switch configurations.
IP subnet for management network traffic
Host names and IP addresses for each of the storage system controllers and all applicable switches
Most storage system controllers are managed through the e0M interface by connecting to the Ethernet service port (wrench icon).
Refer to the Hardware Universe for the latest information.
Cabling requirements
You have the appropriate number and type of cables and cable connectors for your switches. See the Hardware Universe.
Depending on the type of switch you are initially configuring, you need to connect to the switch console port with the included console cable.
