Install and maintain
Upgrade the RCF on the Cisco Nexus 9364D-GX2A switch
Contributors netapp-lisa netapp-jsnyder netapp-yvonneo
Upgrade the reference configuration file (RCF) on Cisco Nexus 9364D-GX2A switches to support new hardware, a new ONTAP version, or a new NX-OS version on AFX 1K or AFX 2K systems.
Note Do not upgrade or downgrade your RCF version to an unsupported version.
Before you begin
  • You must have read the Install or upgrade RCF overview page.
  • Make sure you have a current backup of the switch configuration.
  • Verify that your cluster is fully functional, meaning that there are no errors in the logs or similar issues.
  • You must have the current RCF version.
  • You need a boot configuration in the RCF that reflects the desired boot images.
    If you need to change the boot configuration to reflect the current boot images, you must do so before reapplying the RCF so that the correct version is instantiated on future reboots.
About this task
  • To ensure nondisruptive cluster operations, this procedure has you migrate all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
  • No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily.
  • Because this procedure requires the use of ONTAP commands and Cisco Nexus 9000 Series Switches commands, the steps indicate which CLI you are using to enter commands.
  • The examples in this procedure use the following switch and node nomenclature:
    • The names of the two Cisco switches are cs1 and cs2.
    • The node names are node1-01, node1-02, node1-03, and node1-04.
    • The cluster LIF names are:
      • node1-01_clus1 and node1-01_clus2 for node1-01
      • node1-02_clus1 and node1-02_clus2 for node1-02
      • node1-03_clus1 and node1-03_clus2 for node1-03
      • node1-04_clus1 and node1-04_clus2 for node1-04
    • The cluster1::*> prompt indicates the name of the cluster.
  • The examples shown in this procedure are for AFX 1K systems with switches running RCF 10.0. If you have an AFX 2K system, the input and output can vary.
Step 1: Prepare for the upgrade
Using the ONTAP CLI for the following steps, prepare for the RCF upgrade by suppressing automatic case creation as needed, checking administrative and operational status on the ports, and disabling auto-revert on the cluster LIFs.
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
  2. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  3. Display the cluster ports on each node that are connected to the switches:
    network device-discovery show
    Show example
    cluster1::*> network device-discovery show
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    node1-01/cdp
                e10a   cs1(FLMXXXXXXXX)         Ethernet1/16/3    N9K-C9364D-GX2A
                e10b   cs1(FDOXXXXXXXX)         Ethernet1/13/3    N9K-C9364D-GX2A
                e11a   cs1(FLMXXXXXXXX)         Ethernet1/16/4    N9K-C9364D-GX2A
                e11b   cs1(FDOXXXXXXXX)         Ethernet1/13/4    N9K-C9364D-GX2A
                e1a    cs1(FLMXXXXXXXX)         Ethernet1/16/1    N9K-C9364D-GX2A
                e1b    cs1(FDOXXXXXXXX)         Ethernet1/13/1    N9K-C9364D-GX2A
                e7a    cs1(FLMXXXXXXXX)         Ethernet1/16/2    N9K-C9364D-GX2A
                e7b    cs1(FDOXXXXXXXX)         Ethernet1/13/2    N9K-C9364D-GX2A
    node1-01/lldp
                e10a   cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/3    -
                e10b   cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/3    -
                e11a   cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/4    -
                e11b   cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/4    -
                e1a    cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/1    -
                e1b    cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/1    -
                e7a    cs1 (c8:60:8f:xx:xx:xx)   Ethernet1/16/2    -
                e7b    cs2 (04:e3:87:xx:xx:xx)   Ethernet1/16/2    -
  4. Check the administrative and operational status of each port.
    1. Cluster ports
      1. Verify that all the cluster ports are up with a healthy status:
        network port show -ipspace Cluster
        Show example
        cluster1::*> network port show -ipspace Cluster
        Node: node1-01
        Ignore
                                                          Speed(Mbps) Health   Health
        Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
        e7a       Cluster      Cluster          up   9000  auto/100000 healthy false
        e7b       Cluster      Cluster          up   9000  auto/100000 healthy false
        Node:node1-02
        Ignore
        Node: node1-03
        Ignore
        e7a       Cluster      Cluster          up   9000  auto/10000 healthy  false
        e7b       Cluster      Cluster          up   9000  auto/10000 healthy  false
        Node: node1-04
        Ignore
        cluster1::*>
      2. Verify that all the cluster interfaces (LIFs) are on the home port:
        network interface show -role cluster
        Show example
        cluster1::*> network interface show -role cluster
                    Logical          Status      Network           Current      Current Is
        Vserver     Interface        Admin/Oper  Address/Mask      Node         Port    Home
        Cluster
                    node1-01_clus1   up/up       169.254.3.4/23    node1-01     e7a     true
                    node1-01_clus2   up/up       169.254.3.5/23    node1-01     e7b     true
                    node1-02_clus1   up/up       169.254.3.8/23    node1-02     e7a     true
                    node1-02_clus2   up/up       169.254.3.9/23    node1-02     e7b     true
                    node1-03_clus1   up/up       169.254.1.3/23    node1-03     e7a     true
                    node1-03_clus2   up/up       169.254.1.1/23    node1-03     e7b     true
                    node1-04_clus1   up/up       169.254.1.6/23    node1-04     e7a     true
                    node1-04_clus2   up/up       169.254.1.7/23    node1-04     e7b     true
        8 entries were displayed.
      3. Verify that the cluster displays information for both switches:
        system cluster-switch show -is-monitoring-enabled-operational true
        Show example
        cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true
        Switch                      Type               Address          Model
        cs1(FDOXXXXXXXX)            cluster-network    10.228.137.233   N9K-C9364D-GX2A
             Serial Number: FDOXXXXXXXX
              Is Monitored: true
                    Reason: None
          Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                            10.4(2)
            Version Source: CDP/ISDP
        cs2(FLMXXXXXXXX)            cluster-network    10.228.137.234   N9K-C9364D-GX2A
             Serial Number: FLMXXXXXXXX
              Is Monitored: true
                    Reason: None
                            10.4(2)
    2. HA ports
      1. Verify that all the HA ports are up with a healthy status:
        ha interconnect status show -node <node-name>
        Show example
        cluster1::*> ha interconnect status show -node node1-01
          (system ha interconnect status show)
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                   Is Link 0 Active: true
                   Is Link 1 Active: true
                 IC RDMA Connection: up
                               Slot: 0
                     Debug Firmware: no
        Interconnect Port 0 :
                          Port Name: e1a-17
                                MTU: 4096
                   Link Information: ACTIVE
        Interconnect Port 1 :
                          Port Name: e1b-18
                                MTU: 4096
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
      1. Verify that all the storage ports are up with a healthy status:
        storage port show -port-type ENET
        Show example
        cluster1::*> storage port show -port-type ENET
                                              Speed
        Node               Port Type  Mode    (Gb/s) State    Status
        node1-01
                           e10a ENET  -          100 enabled  online
                           e10b ENET  -          100 enabled  online
                           e11a ENET  -          100 enabled  online
                           e11b ENET  -          100 enabled  online
        node1-02
        node1-03
        node1-04
        16 entries were displayed.
    4. Storage shelf ports
      1. Verify that all the storage shelf ports are up with a healthy status:
        storage shelf port show
        Show example
        cluster1::*> storage shelf port show
        Shelf ID Module State        Internal?
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
              10 B      connected    false
              11 B      connected    false
              12 B      connected    false
              13 B      connected    false
              14 B      connected    false
              15 B      connected    false
      2. Verify that all the storage shelf ports are up with a healthy status:
        storage shelf port show -fields remote-device,remote-port,connector-state
        Show example
        cluster1::*> storage shelf port show -fields remote-device,remote-port,connector-state
        shelf id connector-state remote-port    remote-device
        1.1   0  connected       Ethernet1/17/1 CX9332D-cs1
        1.1   1  connected       Ethernet1/15/1 CX9364D-cs1
        1.1   2  connected       Ethernet1/17/2 CX9332D-cs1
        1.1   3  connected       Ethernet1/15/2 CX9364D-cs1
        1.1   4  connected       Ethernet1/17/3 CX9332D-cs1
        1.1   5  connected       Ethernet1/15/3 CX9364D-cs1
        1.1   6  connected       Ethernet1/17/4 CX9332D-cs1
        1.1   7  connected       Ethernet1/15/4 CX9364D-cs1
        1.1   8  connected       Ethernet1/19/1 CX9332D-cs1
        1.1   9  connected       Ethernet1/17/1 CX9364D-cs1
        1.1   10 connected       Ethernet1/19/2 CX9332D-cs1
        1.1   11 connected       Ethernet1/17/2 CX9364D-cs1
        1.1   12 connected       Ethernet1/19/3 CX9332D-cs1
        1.1   13 connected       Ethernet1/17/3 CX9364D-cs1
        1.1   14 connected       Ethernet1/19/4 CX9332D-cs1
        1.1   15 connected       Ethernet1/17/4 CX9364D-cs1
  5. Disable auto-revert on the cluster LIFs. The cluster LIFs fail over to the partner cluster switch and remain there as you perform this procedure on the targeted switch:
    network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Upgrade the RCF
You use the switch CLI and the ONTAP CLI (as indicated in the following steps) for the RCF upgrade. You upgrade the RCF on the first switch (cs1) and then repeat these steps for the second switch (cs2).
  1. Using the switch CLI, on switch cs1, shut down the ports connected to all the ports of the nodes.
    Caution Make sure to shutdown all connected ports to avoid any network connection issues. Refer to the Knowledge Base article Node out of quorum when migrating cluster LIF during switch OS upgrade for further details.
    cs1# config
    cs1(config)# interface e1/1/1-4,e1/2/1-4,e1/3/1-4,e1/4/1-4,e1/5/1-4,e1/6/1-4,e1/7/1-4,e1/8/1-4
    cs1(config-if-range)# shutdown
    cs1(config)# interface e1/9/1-4,e1/10/1-4,e1/11/1-4,e1/12/1-4,e1/13/1-4,e1/14/1-4,e1/15/1-4,e1/16/1-4
    cs1(config)# interface e1/17/1-4,e1/18/1-4,e1/19/1-4,e1/20/1-4,e1/21/1-4,e1/22/1-4,e1/23/1-4,e1/24/1-4
    cs1(config)# interface e1/25/1-4,e1/26/1-4,e1/27/1-4,e1/28/1-4,e1/29/1-4,e1/30/1-4,e1/31/1-4,e1/32/1-4
    cs1(config)# interface e1/33/1-4,e1/34/1-4,e1/35/1-4,e1/36/1-4,e1/37/1-4,e1/38/1-4,e1/39/1-4,e1/40/1-4
    cs1(config)# interface e1/41/1-4,e1/42/1-4,e1/43/1-4,e1/44/1-4,e1/35/1-4,e1/46/1-4,e1/47/1-4,e1/48/1-4
    cs1(config)# interface e1/49/1-4,e1/50/1-4,e1/51/1-4,e1/52/1-4,e1/53/1-4,e1/54/1-4,e1/55/1-4,e1/56/1-4
    cs1(config)# interface e1/57/1-4,e1/58/1-4,e1/59/1-4,e1/60/1-4,e1/61/1-4,e1/62/1-4
    cs1(config-if-range)# exit
    cs1(config)# exit
  2. Using the ONTAP CLI, verify that the cluster LIFs have failed over to the ports hosted on switch cs1. This might take a few seconds.
    Show example
    Cluster
                node1-01_clus1    up/up      169.254.36.44/16   node1-01      e7a     true
                node1-01_clus2    up/up      169.254.7.5/16     node1-01      e7b     true
                node1-02_clus1    up/up      169.254.197.206/16 node1-02      e7a     true
                node1-02_clus2    up/up      169.254.195.186/16 node1-02      e7b     true
                node1-03_clus1    up/up      169.254.192.49/16  node1-03      e7a     true
                node1-03_clus2    up/up      169.254.182.76/16  node1-03      e7b     true
                node1-04_clus1    up/up      169.254.59.49/16   node1-04      e7a     true
                node1-04_clus2    up/up      169.254.62.244/16  node1-04      e7b     true
  3. Using the ONTAP CLI, verify that the cluster is healthy:
    cluster show
    Show example
    cluster1::*> cluster show
    Node              Health  Eligibility   Epsilon
    node1-01          true    true          false
    node1-02          true    true          false
    node1-03          true    true          true
    node1-04          true    true          false
    4 entries were displayed.
  4. If you have not already done so, using the switch CLI, save a copy of the current switch configuration by copying the output of the following command to a text file:
    show running-config
    1. Use the show diff running-config command to compare with the saved RCF file in the bootflash. Otherwise, use a third-party diff/compare tool.
  5. Save basic configuration details to the write_erase.cfg file on the bootflash.
    Note
    Make sure to configure the following:
    • Username and password
    • Management IP address
    • Default gateway
    • Switch name
    Caution
    If the write_erase.cfg file already exists, rename it to write_erase_old.cfg, as follows:
    cs1# move bootflash:write_erase.cfg write_erase_old.cfg
    cs1# show run | i "username admin password" > bootflash:write_erase.cfg
    cs1# show run | section "vrf context management" >> bootflash:write_erase.cfg
    cs1# show run | section "interface mgmt0" >> bootflash:write_erase.cfg
    cs1# show run | section "switchname" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region ing-racl 1024" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region egr-racl 1024" >> bootflash:write_erase.cfg
    cs1# echo "hardware access-list tcam region ing-l2-qos 1536" >> bootflash:write_erase.cfg
  6. Using the switch CLI, verify that the write_erase.cfg file is populated as expected:
    show file bootflash:write_erase.cfg
  7. Using the switch CLI, erase the current saved configuration:
    write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  8. Using the switch CLI, copy the previously saved basic configuration into the startup configuration:
    copy bootflash:write_erase.cfg startup-config
  9. Using the switch CLI, reboot the switch:
    reload
    This command will reboot the system. (y/n)? [n] y
  10. After the management IP address is reachable again, log in to the switch through SSH.
    You might need to update host file entries related to the SSH keys.
  11. Using the switch CLI, copy the RCF to the bootflash of switch cs1 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP.
    For more information on Cisco commands, refer to the appropriate guide in the Cisco Nexus 9000 Series NX-OS Command Reference.
    copy <protocol>: bootflash: vrf management
    Show example
    This example shows TFTP being used to copy an RCF to the bootflash on switch cs1:
    cs1# copy tftp: bootflash: vrf management
    Enter source filename: NX9364D-GX2A-RCF-v10.0-Shared.txt
    Enter hostname for the tftp server: 172.22.201.50
    Trying to connect to tftp server......Connection to Server Established.
    TFTP get operation was successful
    Copy complete, now saving to disk (please wait)...
  12. Using the switch CLI, apply the RCF previously downloaded to the bootflash.
    This example shows the RCF file NX9364D-GX2A-RCF-v10.0-Shared.txt being installed on switch cs1:
    cs1# copy NX9364D-GX2A-RCF-v10.0-Shared.txt running-config echo-commands
    Caution
    Make sure to thoroughly read the Installation notes, Important Notes, and banner sections of your RCF.
    You must read and follow these instructions to ensure the proper configuration and operation of the switch.
  13. Using the switch CLI, verify that the RCF file is the correct newer version:
    show running-config
    When you check the output to verify you have the correct RCF, make sure that the following information is correct:
    • The RCF banner
    • The node and port settings
    • Customizations
      The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
  14. Reapply any previous customizations to the switch configuration.
    If your switches are running RCF 10.1 or later, you can change the port speed configuration if needed.
  15. Using the switch CLI, after you verify the RCF versions, custom additions, and switch settings are correct, copy the running-config file to the startup-config file.
    copy running-config startup-config
    [] 100% Copy complete
  16. Using the switch CLI, reboot switch cs1. You can ignore the “cluster switch health monitor” alerts and “cluster ports down” events reported on the nodes while the switch reboots.
    reload
  17. Using the ONTAP CLI, verify the health of all the ports on the cluster:
    1. Cluster ports
      1. Verify that cluster ports are up and healthy across all nodes in the cluster:
        Show example
        Node: node1-01
        Ignore
        Node: node1-02
        Ignore
        Node: node1-03
        Ignore
        Node: node1-04
        Ignore
      2. Verify the switch health from the cluster.
        network device-discovery show -protocol cdp
        Show example
        cluster1::*> network device-discovery show -protocol cdp
        node1-01/cdp
                    e10b   cs2(FDOXXXXXXXX)          Ethernet1/13/3    N9K-C9364D-GX2A
                    e11b   cs2(FDOXXXXXXXX)          Ethernet1/13/4    N9K-C9364D-GX2A
                    e1b    cs2(FLMXXXXXXXX)          Ethernet1/13/1    N9K-C9364D-GX2A
                    e7b    cs2(FDOXXXXXXXX)          Ethernet1/13/2    N9K-C9364D-GX2A
        node1-02/cdp
        cs2(FDOXXXXXXXX)            cluster-network    10.228.137.233   N9K-C9364D-GX2A
              Is Monitored: true
                    Reason: None
                            10.4(2)
        cs1(FLMXXXXXXXX)            cluster-network    10.228.137.234   N9K-C9364D-GX2A
              Is Monitored: true
                    Reason: None
                            10.4(2)
        2 entries were displayed.
    2. HA ports
        Show example
                               Node: node1-01
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
        cluster1::*> ha interconnect status show -node node1-02
                               Node: node1-02
                      Link 0 Status: up
                      Link 1 Status: up
                               Slot: 0
                     Debug Firmware: no
                          Port Name: e1a-17
                                MTU: 4096
                          Port Name: e1b-18
                                MTU: 4096
    3. Storage ports
        Show example
                                              Speed
        node1-01
        node1-02
        node1-03
        node1-04
        Show example
        1.1
               0 A      connected    false
               1 A      connected    false
               2 A      connected    false
               3 A      connected    false
               4 A      connected    false
               5 A      connected    false
               6 A      connected    false
               7 A      connected    false
               8 B      connected    false
               9 B      connected    false
      2. Verify the connection status of all the storage shelf ports:
        Show example
  18. Using the ONTAP CLI, verify that the cluster is healthy:
    cluster show
    Show example
  19. Repeat steps 4 to 18 on switch cs2.
  20. Using the ONTAP CLI, enable auto-revert on the cluster LIFs.
    network interface modify -vserver Cluster -lif * -auto-revert true
Step 3: Verify the cluster network configuration and cluster health
After the RCF is upgraded on both switches, verify the cluster network configuration and cluster health.
  1. Using the switch CLI, verify that the switch ports connected to the cluster ports are up.
    show interface brief
    Show example
    cs1# show interface brief | grep up
    Eth1/9/3        1       eth  trunk  up      none                     100G(D) --
    Eth1/9/4        1       eth  trunk  up      none                     100G(D) --
    Eth1/15/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/15/4       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/16/4       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/1       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/2       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/3       1       eth  trunk  up      none                     100G(D) --
    Eth1/17/4       1       eth  trunk  up      none                     100G(D) --
  2. Using the switch CLI, verify that the expected nodes are still connected:
    show cdp neighbors
    Show example
    cs1# show cdp neighbors
    Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                      S - Switch, H - Host, I - IGMP, r - Repeater,
                      V - VoIP-Phone, D - Remotely-Managed-Device,
                      s - Supports-STP-Dispute
    Device-ID          Local Intrfce  Hldtme Capability  Platform      Port ID
    cs2(FDOXXXXXXXX)    Eth1/63        179    R S I s   N9K-C9332D-GX2B   Eth1/31
    cs2(FDOXXXXXXXX)    Eth1/64        179    R S I s   N9K-C9332D-GX2B   Eth1/32
    node1-01            Eth1/4/1       123    H         AFX-1K            e1a
    node1-01            Eth1/4/2       123    H         AFX-1K            e7a
    node1-01            Eth1/4/3       123    H         AFX-1K            e10a
    node1-01            Eth1/4/4       123    H         AFX-1K            e11a
    node1-02            Eth1/9/1       138    H         AFX-1K            e1a
    node1-02            Eth1/9/2       138    H         AFX-1K            e7a
    node1-02            Eth1/9/3       138    H         AFX-1K            e10a
    node1-02            Eth1/9/4       138    H         AFX-1K            e11a
    node1-03            Eth1/15/1      138    H         AFX-1K            e1a
    node1-03            Eth1/15/2      138    H         AFX-1K            e7a
    node1-03            Eth1/15/3      138    H         AFX-1K            e10a
    node1-03            Eth1/15/4      138    H         AFX-1K            e11a
    node1-04            Eth1/16/1      173    H         AFX-1K            e1a
    node1-04            Eth1/16/2      173    H         AFX-1K            e7a
    node1-04            Eth1/16/3      173    H         AFX-1K            e10a
    node1-04            Eth1/16/4      173    H         AFX-1K            e11a
    Total entries displayed: 18
  3. Using the switch CLI, verify that the cluster nodes are in their correct cluster VLANs using the following commands:
    show vlan brief
    show interface trunk
    Show example
    cs1# show vlan brief
    VLAN Name                             Status    Ports
    1    default                          active    Po1, Po999, Eth1/63, Eth1/64
                                                    Eth1/65, Eth1/66, Eth1/1/1
                                                    Eth1/1/2, Eth1/1/3, Eth1/1/4
                                                    Eth1/61/2, Eth1/61/3, Eth1/61/4
                                                    Eth1/62/1, Eth1/62/2, Eth1/62/3
                                                    Eth1/62/4
    17   VLAN0017                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
                                                    Eth1/1/4, Eth1/2/1, Eth1/2/2
                                                    Eth1/61/1, Eth1/61/2, Eth1/61/3
                                                    Eth1/61/4, Eth1/62/1, Eth1/62/2
                                                    Eth1/62/3, Eth1/62/4
    18   VLAN0018                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    30   VLAN0030                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    40   VLAN0040                         active    Eth1/1/1, Eth1/1/2, Eth1/1/3
    cs1# show interface trunk
    Port          Native  Status        Port
                  Vlan                  Channel
    Eth1/1/1      1       trunking      --
    Eth1/1/2      1       trunking      --
    Eth1/1/3      1       trunking      --
    Eth1/1/4      1       trunking      --
    Eth1/2/1      1       trunking      --
    Eth1/2/2      1       trunking      --
    Eth1/2/3      1       trunking      --
    Eth1/2/4      1       trunking      --
    Eth1/62/2     none
    Eth1/62/3     none
    Eth1/62/4     none
    Eth1/63       none
    Eth1/64       none
    Po1           1
    Note For specific port and VLAN usage details, refer to the banner and important notes section in your RCF.
  4. Using the switch CLI, verify that the ISL between cs1 and cs2 is functional:
    show port-channel summary
    Show example
    cs1# show port-channel summary
    Flags:  D - Down        P - Up in port-channel (members)
            I - Individual  H - Hot-standby (LACP only)
            s - Suspended   r - Module-removed
            b - BFD Session Wait
            S - Switched    R - Routed
            U - Up (port-channel)
            p - Up in delay-lacp mode (member)
            M - Not in use. Min-links not met
    Group Port-       Type     Protocol  Member Ports      Channel
    1     Po1(SU)     Eth      LACP      Eth1/63(P)   Eth1/64(P)
    999   Po999(SD)   Eth      NONE      --
    cs1#
  5. Using the ONTAP CLI, verify that the cluster LIFs have reverted to their home port:
    Show example
    Cluster
    If any cluster LIFs have not returned to their home ports, revert them manually from the local node:
    network interface revert -vserver vserver_name -lif <lif-name>
  6. Using the ONTAP CLI, verify that the cluster is healthy:
    cluster show
    Show example
  7. Using the ONTAP CLI, verify the connectivity of the remote cluster interfaces:
    • You can use the following command to display the details of an accessibility check for cluster connectivity:
      network interface check cluster-connectivity show
      Show example
      cluster1::*> network interface check cluster-connectivity show
                                        Source           Destination     Packet
      Node   Date                       LIF              LIF             Loss
      node1-01
             6/4/2025 03:13:33 -04:00   node1-01_clus2  node1-02_clus1   none
             6/4/2025 03:13:34 -04:00   node1-01_clus2  node1-02_clus1   none
      node1-02
             6/4/2025 03:13:33 -04:00   node1-02_clus2  node1-01_clus1   none
             6/4/2025 03:13:34 -04:00   node1-02_clus2  node1-01_clus2   none
    • Alternatively, you can use the following command to check the connectivity:
      cluster ping-cluster -node <node-name>
      Show example
      cluster1::*> cluster ping-cluster -node local
      Host is node1-04
      Getting addresses from network interface table...
      Cluster node1-01_clus1 169.254.36.44 node1-01 e7a
      Cluster node1-01_clus2 169.254.7.5   node1-01 e7b
      Cluster node1-02_clus1 169.254.197.206 node1-02 e7a
      Cluster node1-02_clus2 169.254.195.186 node1-02 e7b
      Cluster node1-03_clus1 169.254.192.49 node1-03 e7a
      Cluster node1-03_clus2 169.254.182.76 node1-03 e7b
      Cluster node1-04_clus1 169.254.59.49 node1-04 e7a
      Cluster node1-04_clus2 169.254.62.244 node1-04 e7b
      Local = 169.254.59.49 169.254.62.244
      Remote = 169.254.36.44 169.254.7.5 169.254.197.206 169.254.195.186 169.254.192.49 169.254.182.76
      Cluster Vserver Id = 4294967293
      Ping status:
      Basic connectivity succeeds on 12 path(s)
      Basic connectivity fails on 0 path(s)
      Detected 9000 byte MTU on 12 path(s):
          Local 169.254.59.49 to Remote 169.254.182.76
          Local 169.254.59.49 to Remote 169.254.192.49
          Local 169.254.59.49 to Remote 169.254.195.186
          Local 169.254.59.49 to Remote 169.254.197.206
          Local 169.254.59.49 to Remote 169.254.36.44
          Local 169.254.59.49 to Remote 169.254.7.5
          Local 169.254.62.244 to Remote 169.254.182.76
          Local 169.254.62.244 to Remote 169.254.192.49
          Local 169.254.62.244 to Remote 169.254.195.186
          Local 169.254.62.244 to Remote 169.254.197.206
          Local 169.254.62.244 to Remote 169.254.36.44
          Local 169.254.62.244 to Remote 169.254.7.5
      Larger than PMTU communication succeeds on 12 path(s)
      RPC status:
      6 paths up, 0 paths down (tcp check)
      6 paths up, 0 paths down (udp check)
What's next?
After you've upgraded the RCF on your switches, you verify SSH for log collection.
