Install and maintain
Install or upgrade the reference configuration file (RCF) overview
Contributors netapp-yvonneo
You install the RCF after setting up the Nexus 9364D-GX2A switch for the first time. You upgrade your RCF version when you have an existing version of the RCF file installed on your switch.
Refer to the Knowledge Base article How to clear configuration on a Cisco interconnect switch while retaining remote connectivity for further information when installing or upgrading your RCF.
Available RCF configuration
  • Cluster-HA-Storage AFX - All ports are configured in 4x100GbE breakout mode that universally supports AFX node clusters, HA, storage ports, and NX224 storage shelf ports. 400GbE ISL between switches. (Cluster-HA-Storage AFX RCF_vxx.x).
For specific port and VLAN usage details, refer to the banner and important notes section in your RCF. Refer to Cisco Ethernet Switches for more information.
Suggested documentation
  • Cisco Ethernet Switches (NSS)
    Consult the switch compatibility table for the supported ONTAP and RCF versions on the NetApp Support Site. Note that there can be command dependencies between the command syntax in the RCF and the syntax found in specific versions of NX-OS.
  • Cisco Nexus 9000 Series Switches
    Refer to the appropriate software and upgrade guides available on the Cisco website for complete documentation on the Cisco switch upgrade and downgrade procedures.
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The names of the two Cisco switches are cs1 and cs2.
  • The node names are node1-01, node1-02, node1-03, and node1-04.
  • The cluster LIF names are node1-01_clus1, node1-01_clus2, node1-02_clus1, node1-02_clus2, node1-03_clus1, node1-03_clus2, node1-04_clus1, and node1-04_clus2.
  • The cluster1::*> prompt indicates the name of the cluster.
Refer to the Hardware Universe to verify the correct cluster ports on your platforms.
Note The command outputs might vary depending on different releases of ONTAP.
Commands used
The procedure requires the use of both ONTAP commands and Cisco Nexus 9000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
What's next?
After you've reviewed the install RCF or upgrade RCF procedure, you install the RCF or upgrade your RCF as required.
