Install and maintain
Reset the Cisco Nexus 9364D-GX2A switch to factory default settings
Contributors netapp-lisa netapp-jsnyder
Reset a Cisco Nexus 9364D-GX2A switch to factory default settings when the switch is being decommissioned or when it fails and cannot be recovered through normal configuration methods.
Before you begin
You must be connected to the switch using the serial console.
About this task
  • This task resets the configuration of the management network.
  • The reload command used in this procedure reboots the switch, which interrupts all network traffic passing through it. (You should perform this procedure during a maintenance window when the switch is not in use.)
Steps
  1. Erase the existing startup configuration:
    write erase
    (cs2)# write erase
    Warning: This command will erase the startup-configuration.
    Do you wish to proceed anyway? (y/n) [n] y
  2. Reload the NX-OS:
    reload
    (cs2)# reload
    This command will reboot the system. (y/n)? [n] y
    The system reboots and enters the configuration wizard.
    Note During the reboot, if you receive the prompt “Abort Auto Provisioning and continue with normal setup? (yes/no)[n]”, respond yes to proceed.
  3. If the switch is being decommissioned, you are done with this procedure; otherwise, you need to configure the switch using the Configure switch workflow.
