Install and maintain
Review documentation requirements for the Cisco Nexus 9364D-GX2A switch
Contributors netapp-lisa netapp-jsnyder
Review the applicable Cisco switch documentation and NetApp systems documentation for Cisco Nexus 9364D-GX2A switch installation, configuration, and maintenance in AFX 1K and AFX 2K systems.
Switch documentation
To set up the Cisco Nexus 9364D-GX2A switches, you need the following documentation from Cisco Nexus 9000 Series Switches Support.
Document title Description
Provides detailed information about site requirements, switch hardware details, and installation options.
Cisco Nexus 9000 Series Switch Software Configuration Guides (choose the guide for the NX-OS release installed on your switches)
Provides initial switch configuration information that you need before you can configure the switch for ONTAP operation.
Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide (choose the guide for the NX-OS release installed on your switches)
Provides information on how to downgrade the switch to ONTAP supported switch software, if necessary.
Provides links to the various command references provided by Cisco.
Describes the system messages for Cisco Nexus 9000 series switches, those that are informational, and others that might help diagnose problems with links, internal hardware, or the system software.
Cisco Nexus 9000 Series NX-OS Release Notes (choose the notes for the NX-OS release installed on your switches)
Describes the features, bugs, and limitations for the Cisco Nexus 9000 Series.
Provides international agency compliance, safety, and statutory information for the Nexus 9000 series switches.
ONTAP systems documentation
To set up an ONTAP system, you need the following documents for your version of the operating system.
Name Description
Describes how to install NetApp hardware.
Provides detailed information about all aspects of the ONTAP releases.
Provides NetApp hardware configuration and compatibility information.
