Install and maintain
Learn about installing or upgrading NX-OS on the Cisco Nexus 9808 switch
Contributors netapp-yvonneo netapp-jsnyder
Install or upgrade the NX-OS on Cisco Nexus 9808 switches for AFX 2K systems.
Note NX-OS installation or upgrade is independent of reference configuration file (RCF) installation or upgrade. If you are installing or upgrading both the NX-OS and RCF, it is recommended you install or upgrade NX-OS first.
  • Install the NX-OS
    You install the NX-OS on the switches as part of a new AFX 2K system installation, a supervisor module replacement, or a switch reset to factory default settings.
  • Upgrade the NX-OS
    You upgrade the NX-OS on the switches to support new hardware or a new ONTAP version on your AFX 2K system.
