Install and maintain
Review documentation requirements for the Cisco Nexus 9808 switch
Contributors netapp-yvonneo netapp-jsnyder netapp-lisa
Review the applicable Cisco switch documentation and NetApp systems documentation for Cisco Nexus 9808 switch installation, configuration, and maintenance in AFX 2K systems.
Note For step-by-step instructions to install and configure your switches as part of a new AFX 2K system, see the Install and configure switches in an AFX system workflow.
To install and configure your Cisco Nexus 9808 switches as part of a new AFX 2K system, you can reference the following Cisco documents so you are familiar with the switch release notes, safety information, installation options, initial software configuration, and command references.
After you install and configure your switches, you can reference the applicable Cisco documents to maintain your switches.
All of these documents are available on the Cisco Nexus 9000 Series Switches Support page.
Task type Cisco document title Description
Cisco Nexus 9000 Series NX-OS Release Notes (choose the notes for the NX-OS release installed on your switches)
Describes the features, bugs, and limitations for the Cisco Nexus 9000 Series.
Provides international agency compliance, safety, and statutory information for the Nexus 9000 series switches.
Provides detailed information about site requirements, switch hardware details, and installation options.
Cisco Nexus 9000 Series Switch Software Configuration Guides (choose the guide for the NX-OS release installed on your switches)
Provides initial switch configuration information that you need before you can configure the switch for ONTAP operation.
Install and configure, and maintain
Provides links to the various command references provided by Cisco.
Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide (choose the guide for the NX-OS release installed on your switches)
Provides information on how to downgrade the switch to ONTAP supported switch software, if necessary.
Maintain
Describes the system messages for Cisco Nexus 9000 series switches, those that are informational, and others that might help diagnose problems with links, internal hardware, or the system software.
To install and configure your Cisco Nexus 9808 switches as part of a new AFX 2K system, you can reference the following NetApp systems documents and resources so you are familiar with the AFX systems, supported ONTAP releases, supported hardware configurations, and system installation requirements.
Task type ONTAP document title Description
Describes how to install NetApp hardware.
Provides detailed information about all aspects of the ONTAP releases.
Provides NetApp hardware configuration and compatibility information.
Provides more information about storage system installation requirements.
