Install hardware for the NVIDIA SN2100 storage switch
Install the NVIDIA SN2100 storage switch hardware by following NVIDIA's documentation. Hardware installation is the first step before configuring the switch for storage network operation.
Follow these steps to set up and configure your SN2100 switches. Refer to NVIDIA's documentation for detailed instructions.
Steps
Review the configuration requirements.
Follow the instructions in the NVIDIA Switch Installation Guide.
What's next?
After you've installed your hardware, you can review cabling and configuration requirements.
