Install and maintain
Configure SNMPv3 for switch log collection
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Follow this procedure to configure SNMPv3, which supports switch log collection and Switch Health Monitoring (SHM).
About this task
The following commands configure an SNMPv3 username on NVIDIA SN2100 switches:
  • For no authentication: net add snmp-server username SNMPv3_USER auth-none
  • For MD5/SHA authentication: net add snmp-server username SNMPv3_USER [auth-md5|auth-sha] AUTH-PASSWORD
  • For MD5/SHA authentication with AES/DES encryption: net add snmp-server username SNMPv3_USER [auth-md5|auth-sha] AUTH-PASSWORD [encrypt-aes|encrypt-des] PRIV-PASSWORD
The following command configures an SNMPv3 username on the ONTAP side: cluster1::*> security login create -user-or-group-name SNMPv3_USER -application snmp -authentication-method usm -remote-switch-ipaddress ADDRESS
The following command establishes the SNMPv3 username with SHM: cluster1::*> system switch ethernet modify -device DEVICE -snmp-version SNMPv3 -community-or-username SNMPv3_USER
Steps
  1. Set up the SNMPv3 user on the switch to use authentication and encryption:
    net show snmp status
    Show example
    cumulus@sw1:~$ net show snmp status
    Simple Network Management Protocol (SNMP) Daemon.
    Current Status                     active (running)
    Reload Status                      enabled
    Listening IP Addresses             all vrf mgmt
    Main snmpd PID                     4318
    Version 1 and 2c Community String  Configured
    Version 3 Usernames                Not Configured
    cumulus@sw1:~$
    cumulus@sw1:~$ net add snmp-server username SNMPv3User auth-md5 <password> encrypt-aes <password>
    cumulus@sw1:~$ net commit
    --- /etc/snmp/snmpd.conf        2020-08-02 21:09:34.686949282 +0000
    +++ /run/nclu/snmp/snmpd.conf   2020-08-11 00:13:51.826126655 +0000
    @@ -1,26 +1,28 @@
     # Auto-generated config file: do not edit. #
     agentaddress udp:@mgmt:161
     agentxperms 777 777 snmp snmp
     agentxsocket /var/agentx/master
     createuser _snmptrapusernameX
    +createuser SNMPv3User MD5 <password> AES <password>
     ifmib_max_num_ifaces 500
     iquerysecname _snmptrapusernameX
     master agentx
     monitor -r 60 -o laNames -o laErrMessage "laTable" laErrorFlag != 0
     pass -p 10 1.3.6.1.2.1.1.1 /usr/share/snmp/sysDescr_pass.py
     pass_persist 1.2.840.10006.300.43 /usr/share/snmp/ieee8023_lag_pp.py
     pass_persist 1.3.6.1.2.1.17 /usr/share/snmp/bridge_pp.py
     pass_persist 1.3.6.1.2.1.31.1.1.1.18 /usr/share/snmp/snmpifAlias_pp.py
     pass_persist 1.3.6.1.2.1.47 /usr/share/snmp/entity_pp.py
     pass_persist 1.3.6.1.2.1.99 /usr/share/snmp/entity_sensor_pp.py
     pass_persist 1.3.6.1.4.1.40310.1 /usr/share/snmp/resq_pp.py
     pass_persist 1.3.6.1.4.1.40310.2 /usr/share/snmp/cl_drop_cntrs_pp.py
     pass_persist 1.3.6.1.4.1.40310.3 /usr/share/snmp/cl_poe_pp.py
     pass_persist 1.3.6.1.4.1.40310.4 /usr/share/snmp/bgpun_pp.py
     pass_persist 1.3.6.1.4.1.40310.5 /usr/share/snmp/cumulus-status.py
     pass_persist 1.3.6.1.4.1.40310.6 /usr/share/snmp/cumulus-sensor.py
     pass_persist 1.3.6.1.4.1.40310.7 /usr/share/snmp/vrf_bgpun_pp.py
    +rocommunity cshm1! default
     rouser _snmptrapusernameX
    +rouser SNMPv3User priv
     sysobjectid 1.3.6.1.4.1.40310
     sysservices 72
    -rocommunity cshm1! default
    net add/del commands since the last "net commit"
    User        Timestamp                   Command
    SNMPv3User  2020-08-11 00:13:51.826987  net add snmp-server username SNMPv3User auth-md5 <password> encrypt-aes <password>
    cumulus@sw1:~$
    Main snmpd PID                     24253
    Version 3 Usernames                Configured     <---- Configured here
    cumulus@sw1:~$
  2. Set up the SNMPv3 user on the ONTAP side:
    security login create -user-or-group-name SNMPv3User -application snmp -authentication-method usm -remote-switch-ipaddress 10.231.80.212
    Show example
    cluster1::*> security login create -user-or-group-name SNMPv3User -application snmp -authentication-method usm -remote-switch-ipaddress 10.231.80.212
    Enter the authoritative entity's EngineID [remote EngineID]:
    Which authentication protocol do you want to choose (none, md5, sha, sha2-256)
    [none]: md5
    Enter the authentication protocol password (minimum 8 characters long):
    Enter the authentication protocol password again:
    Which privacy protocol do you want to choose (none, des, aes128) [none]: aes128
    Enter privacy protocol password (minimum 8 characters long):
    Enter privacy protocol password again:
  3. Configure SHM to monitor with the new SNMPv3 user:
    system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance
    Show example
    cluster1::*> system switch ethernet show-all -device "sw1 (b8:59:9f:09:7c:22)" -instance
                                       Device Name: sw1 (b8:59:9f:09:7c:22)
                                        IP Address: 10.231.80.212
                                      SNMP Version: SNMPv2c
                                     Is Discovered: true
    DEPRECATED-Community String or SNMPv3 Username: -
               Community String or SNMPv3 Username: cshm1!
                                      Model Number: MSN2100-CB2FC
                                    Switch Network: cluster-network
                                  Software Version: Cumulus Linux version 4.4.3 running on Mellanox Technologies Ltd. MSN2100
                         Reason For Not Monitoring: None
                          Source Of Switch Version: LLDP
                                    Is Monitored ?: true
                       Serial Number of the Device: MT2110X06399  <---- serial number to check
                                       RCF Version: MSN2100-RCF-v1.9X6-Cluster-LLDP Aug-18-2022
    cluster1::*>
    cluster1::*> system switch ethernet modify -device "sw1 (b8:59:9f:09:7c:22)" -snmp-version SNMPv3 -community-or-username SNMPv3User
  4. Verify that the serial number to be queried with the newly created SNMPv3 user is the same as detailed in the previous step once the SHM polling period has completed.
    system switch ethernet polling-interval show
    Show example
    cluster1::*> system switch ethernet polling-interval show
             Polling Interval (in minutes): 5
                                      SNMP Version: SNMPv3
                                     Is Discovered: true
               Community String or SNMPv3 Username: SNMPv3User
