Install and maintain
Review documentation requirements for NVIDIA SN2100 storage switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Review the switch and controller documentation required to set up NVIDIA SN2100 storage switches and configure them in an ONTAP storage network.
The following table lists the documentation available for the NVIDIA SN2100 switches.
Title Description
Describes how to setup and configure your NVIDIA SN2100 switches, including installing Cumulus Linux and applicable RCFs.
Describes how to migrate from environments that use Cisco storage switches to environments that use NVIDIA SN2100 storage switches.
Describes how to migrate to a two-node switched environment using NVIDIA SN2100 switches.
Describes the procedure to replace a defective NVIDIA SN2100 storage switch and download Cumulus Linux and reference configuration file.
ONTAP systems documentation
To set up an ONTAP system, you need the following documents for your version of the operating system.
Name Description
Controller-specific Installation and Setup Instructions
Describes how to install NetApp hardware.
Provides detailed information about all aspects of the ONTAP releases.
Allows you to confirm supported hardware, such as storage switches and cables, for your platform model.
