Install and maintain
Install hardware for the NVIDIA SN2100 cluster switch
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Install the NVIDIA SN2100 cluster switch hardware by following NVIDIA's documentation. Hardware installation is the first step before configuring the switch for cluster operation.
Follow these steps to set up and configure your SN2100 switches. Refer to NVIDIA's documentation for detailed instructions.
Steps
  1. Review the configuration requirements.
  2. Follow the instructions in the NVIDIA Switch Installation Guide.
What's next?
After you've installed your hardware, you can review cabling and configuration requirements.
