Install and maintain
Review cabling and configuration guidelines for NVIDIA SN2100 cluster switches
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Review the cabling and configuration considerations for NVIDIA SN2100 cluster switches before deployment.
NVIDIA port details
Switch ports
Ports usage
swp1s0-3
4x10GbE breakout cluster port nodes
swp2s0-3
4x25GbE breakout cluster port nodes
swp3-14
40/100GbE cluster port nodes
swp15-16
100GbE Inter-Switch Link (ISL) ports
Refer to the Hardware Universe for more information on switch ports.
If you are experiencing link-up delays of more than five seconds, Cumulus Linux 5.4 and later includes support for fast link-up. You can configure the links by using the nv set command as follows:
nv set interface <interface-id> link fast-linkup on
nv config apply
reload the switchd
Show example
cumulus@cumulus-cs13:mgmt:~$ nv set interface swp5 link fast-linkup on
cumulus@cumulus-cs13:mgmt:~$ nv config apply
switchd need to reload on this config change
Are you sure? [y/N] y
applied [rev_id: 22]
Only switchd reload required
Support for copper connections
The following configuration changes are required to fix this issue.
Cumulus Linux 4.4.3
  1. Identify the name for each interface using 40GbE/100GbE copper cables:
    cumulus@cumulus:mgmt:~$ net show interface pluggables
    Interface  Identifier     Vendor Name     Vendor PN    Vendor SN      Vendor Rev
    swp3       0x11 (QSFP28)  Molex           112-00576    93A2229911111  B0
    swp4       0x11 (QSFP28)  Molex           112-00576    93A2229922222  B0
  2. Add the following two lines to the /etc/cumulus/switchd.conf file for every port (swp<n>) that is using 40GbE/100GbE copper cables:
    • interface.swp<n>.enable_media_depended_linkup_flow=TRUE
    • interface.swp<n>.enable_short_tuning=TRUE
      For example:
      cumulus@cumulus:mgmt:~$ sudo nano /etc/cumulus/switchd.conf
      interface.swp3.enable_media_depended_linkup_flow=TRUE
      interface.swp3.enable_short_tuning=TRUE
      interface.swp4.enable_media_depended_linkup_flow=TRUE
      interface.swp4.enable_short_tuning=TRUE
  3. Restart the switchd service:
    cumulus@cumulus:mgmt:~$ sudo systemctl restart switchd.service
  4. Confirm that the ports are up:
    cumulus@cumulus:mgmt:~$ net show interface all
    State  Name      Spd   MTU    Mode       LLDP              Summary
    UP     swp3      100G  9216   Trunk/L2                     Master: bridge(UP)
    UP     swp4      100G  9216   Trunk/L2                     Master: bridge(UP)
Cumulus Linux 5.x
    cumulus@cumulus:mgmt:~$ nv show interface --view=pluggables
  2. Configure the links using the nv set command as follows:
    • nv set interface <interface-id> link fast-linkup on
    • nv config apply
    • Reload the switchd service
      For example:
      cumulus@cumulus:mgmt:~$ nv set interface swp5 link fast-linkup on
      cumulus@cumulus:mgmt:~$ nv config apply
  3. Confirm that the ports are up:
Refer to the Knowledge Base article SN2100 switch fails to connect using 40/100GbE copper cables for further details.
On Cumulus Linux 4.4.2, copper connections are not supported on SN2100 switches with X1151A NIC, X1146A NIC, or onboard 100GbE ports. For example:
  • AFF A800 on ports e0a and e0b
  • AFF A320 on ports e0g and e0h
QSA module
When using QSFP+ (40GbE) to SFP+ (10GbE) adapters or QSFP28 (100GbE) to SFP28 (25GbE) adapters (QSA), insert them in non-breakout 40GbE/100GbE switch ports (swp3-swp14). Do not insert the QSA module in a port that is configured for breakout.
When a QSA module is used to connect to the 10GbE/25GbE cluster ports on a platform, the link might not come up.
To resolve this issue, do the following:
  • For 10GbE, manually set the link speed to 10000 and set auto-negotiation to off.
  • For 25GbE, manually set the link speed to 25000 and set auto-negotiation to off.
Setting interface speed on breakout ports
Depending on the transceiver in the switch port, you might need to set the speed on the switch interface to a fixed speed. If using 10GbE and 25GbE breakout ports or QSA module, verify that auto-negotiation is off and set the interface speed on the switch.
Cumulus Linux 4.4.3
For example:
cumulus@cumulus:mgmt:~$ net add int swp1s3 link autoneg off && net com
--- /etc/network/interfaces     2019-11-17 00:17:13.470687027 +0000
+++ /run/nclu/ifupdown2/interfaces.tmp  2019-11-24 00:09:19.435226258 +0000
@@ -37,21 +37,21 @@
     alias 10G Intra-Cluster Node
     link-autoneg off
     link-speed 10000  <---- port speed set
     mstpctl-bpduguard yes
     mstpctl-portadminedge yes
     mtu 9216
auto swp1s3
iface swp1s3
-    link-autoneg off
+    link-autoneg on
     mtu 9216
auto swp2s0
iface swp2s0
     alias 25G Intra-Cluster Node
     link-autoneg off
     link-speed 25000 <---- port speed set
Check the interface and port status to verify that the settings are applied:
UP     swp1s0     10G   9216   Trunk/L2    cs07 (e4c)       Master: br_default(UP)
UP     swp1s1     10G   9216   Trunk/L2    cs07 (e4d)       Master: br_default(UP)
UP     swp1s2     10G   9216   Trunk/L2    cs08 (e4c)       Master: br_default(UP)
UP     swp1s3     10G   9216   Trunk/L2    cs08 (e4d)       Master: br_default(UP)
UP     swp3       40G   9216   Trunk/L2    cs03 (e4e)       Master: br_default(UP)
UP     swp4       40G   9216   Trunk/L2    cs04 (e4e)       Master: br_default(UP)
DN     swp5       N/A   9216   Trunk/L2                     Master: br_default(UP)
DN     swp6       N/A   9216   Trunk/L2                     Master: br_default(UP)
DN     swp7       N/A   9216   Trunk/L2                     Master: br_default(UP)
UP     swp15      100G  9216   BondMember  cs01 (swp15)     Master: cluster_isl(UP)
UP     swp16      100G  9216   BondMember  cs01 (swp16)     Master: cluster_isl(UP)
Cumulus Linux 5.x
For example:
cumulus@cumulus:mgmt:~$ nv set interface swp1s3 link auto-negotiate off
cumulus@cumulus:mgmt:~$ nv set interface swp1s3 link speed 10G
cumulus@cumulus:mgmt:~$ nv show interface swp1s3
link
  auto-negotiate        off                     off                     off
  duplex                full                    full                    full
  speed                 10G                     10G                     10G
  fec                   auto                    auto                    auto
  mtu                   9216                    9216                    9216
[breakout]
  state                 up                      up                      up
Refer to the Hardware Universe and the Knowledge Base article What additional information do I need to install my equipment that is not in HWU for more information.
What's next?
After you've reviewed your cabling and configuration requirements, you can cable the NS224 shelves as switch-attached storage.
