Install and maintain
Migrate from NetApp CN1610 cluster switches to Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches
Contributors netapp-yvonneo netapp-jsnyder
Migrate existing NetApp CN1610 cluster switches to Cisco Nexus 9336C-FX2 and 9336C-FX2-T cluster switches without disrupting cluster operation.
Review requirements
You must be aware of certain configuration information, port connections and cabling requirements when you are replacing NetApp CN1610 cluster switches with Cisco 9336C-FX2 and 9336C-FX2-T cluster switches. You must also verify the switch serial number to ensure that the correct switch is migrated.
Supported switches
The following cluster switches are supported:
  • NetApp CN1610
  • Cisco 9336C-FX2
  • Cisco 9336C-FX2-T
For details of supported ports and their configurations, refer to the Hardware Universe. Refer to What additional information do I need to install my equipment that is not in HWU? for more information about switch installation requirements.
What you'll need
Verify that your configuration meets the following requirements:
  • The existing cluster is correctly set up and functioning.
  • All cluster ports are in the up state to ensure nondisruptive operations.
  • The Cisco 9336C-FX2 and 9336C-FX2-T cluster switches are configured and operating under the correct version of NX-OS installed with the reference configuration file (RCF) applied.
  • The existing cluster network configuration has the following:
    • A redundant and fully functional NetApp cluster using NetApp CN1610 switches.
    • Management connectivity and console access to both the NetApp CN1610 switches and the new switches.
    • All cluster LIFs in the up state with the cluster LIFs are on their home ports.
  • Some of the ports are configured on Cisco 9336C-FX2 and 9336C-FX2-T switches to run at 40GbE or 100GbE.
  • You have planned, migrated, and documented 40GbE and 100GbE connectivity from nodes to Cisco 9336C-FX2 and 9336C-FX2-T cluster switches.
Migrate the switches
About the examples
The examples in this procedure use the following switch and node nomenclature:
  • The existing CN1610 cluster switches are C1 and C2.
  • The new 9336C-FX2 cluster switches are cs1 and cs2.
  • The nodes are node1 and node2.
  • The cluster LIFs are node1_clus1 and node1_clus2 on node 1, and node2_clus1 and node2_clus2 on node 2 respectively.
  • The cluster1::*> prompt indicates the name of the cluster.
  • The cluster ports used in this procedure are e3a and e3b.
About this task
This procedure covers the following scenario:
  • Switch C2 is replaced by switch cs2 first.
    • Shut down the ports to the cluster nodes. All ports must be shut down simultaneously to avoid cluster instability.
      • All cluster LIFs fail over to the new switch cs2.
    • The cabling between the nodes and C2 is then disconnected from C2 and reconnected to cs2.
  • Switch C1 is replaced by switch cs1.
      • All cluster LIFs fail over to the new switch cs1.
    • The cabling between the nodes and C1 is then disconnected from C1 and reconnected to cs1.
Note No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To ensure non-disruptive cluster operations, the following procedure fails over all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Step 1: Prepare for migration
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all -message MAINT=xh
    where x is the duration of the maintenance window in hours.
  2. Change the privilege level to advanced, entering y when prompted to continue:
    set -privilege advanced
    The advanced prompt (*>) appears.
  3. Disable auto-revert on the cluster LIFs.
    By disabling auto-revert for this procedure, the cluster LIFs will not automatically move back to their home port. They remain on the current port while it continues to be up and operational.
    network interface modify -vserver Cluster -lif * -auto-revert false
Step 2: Configure ports and cabling
  1. Determine the administrative or operational status for each cluster interface.
    Each port should display up for Link and healthy for Health Status.
    1. Display the network port attributes:
      network port show -ipspace Cluster
      Show example
      cluster1::*> network port show -ipspace Cluster
      Node: node1
        Ignore
                                                       Speed(Mbps)  Health   Health
      Port      IPspace    Broadcast Domain Link MTU   Admin/Oper   Status   Status
      e3a       Cluster    Cluster          up   9000  auto/100000  healthy  false
      e3b       Cluster    Cluster          up   9000  auto/100000  healthy  false
      Node: node2
        Ignore
    2. Display information about the LIFs and their designated home nodes:
      network interface show -vserver Cluster
      Each LIF should display up/up for Status Admin/Oper and true for Is Home.
      Show example
      cluster1::*> network interface show -vserver Cluster
                  Logical      Status     Network            Current     Current Is
      Vserver     Interface    Admin/Oper Address/Mask       Node        Port    Home
      Cluster
                  node1_clus1  up/up      169.254.209.69/16  node1       e3a     true
                  node1_clus2  up/up      169.254.49.125/16  node1       e3b     true
                  node2_clus1  up/up      169.254.47.194/16  node2       e3a     true
                  node2_clus2  up/up      169.254.19.183/16  node2       e3b     true
  2. The cluster ports on each node are connected to existing cluster switches in the following way (from the nodes' perspective) using the command:
    network device-discovery show -protocol
    Show example
    cluster1::*> network device-discovery show -protocol cdp
    Node/       Local  Discovered
    Protocol    Port   Device (LLDP: ChassisID)  Interface         Platform
    node1      /cdp
                e3a    C1 (6a:ad:4f:98:3b:3f)    0/1               -
                e3b    C2 (6a:ad:4f:98:4c:a4)    0/1               -
    node2      /cdp
                e3a    C1 (6a:ad:4f:98:3b:3f)    0/2               -
                e3b    C2 (6a:ad:4f:98:4c:a4)    0/2               -
  3. The cluster ports and switches are connected in the following way (from the switches' perspective) using the command:
    show cdp neighbors
    Show example
    C1# show cdp neighbors
    Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                      S - Switch, H - Host, I - IGMP, r - Repeater,
                      V - VoIP-Phone, D - Remotely-Managed-Device,
                      s - Supports-STP-Dispute
    Device-ID             Local Intrfce Hldtme Capability  Platform         Port ID
    node1                 Eth1/1        124    H           AFF-A400         e3a
    node2                 Eth1/2        124    H           AFF-A400         e3a
    C2                    0/13          179    S I s       CN1610           0/13
    C2                    0/14          175    S I s       CN1610           0/14
    C2                    0/15          179    S I s       CN1610           0/15
    C2                    0/16          175    S I s       CN1610           0/16
    C2# show cdp neighbors
    node1                 Eth1/1        124    H           AFF-A400         e3b
    node2                 Eth1/2        124    H           AFF-A400         e3b
    C1                    0/13          175    S I s       CN1610           0/13
    C1                    0/14          175    S I s       CN1610           0/14
    C1                    0/15          175    S I s       CN1610           0/15
    C1                    0/16          175    S I s       CN1610           0/16
  4. Verify the connectivity of the remote cluster interfaces:
ONTAP 9.9.1 and later
You can use the network interface check cluster-connectivity command to start an accessibility check for cluster connectivity and then display the details:
network interface check cluster-connectivity start and network interface check cluster-connectivity show
cluster1::*> network interface check cluster-connectivity start
NOTE: Wait for a number of seconds before running the show command to display the details.
cluster1::*> network interface check cluster-connectivity show
                                  Source           Destination      Packet
Node   Date                       LIF              LIF              Loss
node1
       3/5/2022 19:21:18 -06:00   node1_clus2      node2-clus1      none
       3/5/2022 19:21:20 -06:00   node1_clus2      node2_clus2      none
node2
       3/5/2022 19:21:18 -06:00   node2_clus2      node1_clus1      none
       3/5/2022 19:21:20 -06:00   node2_clus2      node1_clus2      none
All ONTAP releases
For all ONTAP releases, you can also use the cluster ping-cluster -node <name> command to check the connectivity:
cluster1::*> cluster ping-cluster -node local
Host is node2
Getting addresses from network interface table...
Cluster node1_clus1 169.254.209.69 node1     e3a
Cluster node1_clus2 169.254.49.125 node1     e3b
Cluster node2_clus1 169.254.47.194 node2     e3a
Cluster node2_clus2 169.254.19.183 node2     e3b
Local = 169.254.47.194 169.254.19.183
Remote = 169.254.209.69 169.254.49.125
Cluster Vserver Id = 4294967293
Ping status:....
Basic connectivity succeeds on 4 path(s)
Basic connectivity fails on 0 path(s)
Detected 9000 byte MTU on 4 path(s):
    Local 169.254.19.183 to Remote 169.254.209.69
    Local 169.254.19.183 to Remote 169.254.49.125
    Local 169.254.47.194 to Remote 169.254.209.69
    Local 169.254.47.194 to Remote 169.254.49.125
Larger than PMTU communication succeeds on 4 path(s)
RPC status:
2 paths up, 0 paths down (tcp check)
2 paths up, 0 paths down (udp check)
  1. On switch C2, shut down the ports connected to the cluster ports of the nodes in order to fail over the cluster LIFs.
    Caution Do not attempt to manually migrate the cluster LIFs.
    (C2)# configure
    (C2)(Config)# interface 0/1-0/12
    (C2)(Interface 0/1-0/12)# shutdown
    (C2)(Interface 0/1-0/12)# exit
    (C2)(Config)# exit
  2. Move the node cluster ports from the old switch C2 to the new switch cs2, using appropriate cabling supported by Cisco 9336C-FX2 and 9336C-FX2-T.
  3. Display the network port attributes:
    Show example
    Node: node1
        Ignore
    Node: node2
        Ignore
  4. The cluster ports on each node are now connected to cluster switches in the following way, from the nodes' perspective:
    Show example
    node1      /cdp
                e3a    C1  (6a:ad:4f:98:3b:3f)   0/1               CN1610
                e3b    cs2 (b8:ce:f6:19:1a:7e)   Ethernet1/1/1     N9K-C9336C-FX2
    node2      /cdp
                e3a    C1  (6a:ad:4f:98:3b:3f)   0/2               CN1610
                e3b    cs2 (b8:ce:f6:19:1b:96)   Ethernet1/1/2     N9K-C9336C-FX2
  5. On switch cs2, verify that all node cluster ports are up:
    Show example
    Vserver     Interfac     Admin/Oper Address/Mask       Node        Port    Home
    Cluster
                node1_clus1  up/up      169.254.3.4/16     node1       e0b     false
                node1_clus2  up/up      169.254.3.5/16     node1       e0b     true
                node2_clus1  up/up      169.254.3.8/16     node2       e0b     false
                node2_clus2  up/up      169.254.3.9/16     node2       e0b     true
  6. On switch C1, shut down the ports connected to the cluster ports of the nodes in order to fail over the cluster LIFs.
    (C1)# configure
    (C1)(Config)# interface 0/1-0/12
    (C1)(Interface 0/1-0/12)# shutdown
    (C1)(Interface 0/1-0/12)# exit
    (C1)(Config)# exit
  7. Move the node cluster ports from the old switch C1 to the new switch cs1, using appropriate cabling supported by Cisco 9336C-FX2 and 9336C-FX2-T.
  8. Verify the final configuration of the cluster:
    Show example
    Node: node1
        Ignore
    Node: node2
        Ignore
  9. The cluster ports on each node are now connected to cluster switches in the following way, from the nodes' perspective:
    Show example
    node1      /cdp
                e3a    cs1 (b8:ce:f6:19:1a:7e)   Ethernet1/1/1   N9K-C9336C-FX2
    node2      /cdp
  10. On switches cs1 and cs2, verify that all node cluster ports are up:
    Show example
    Node: node1
        Ignore
    e0a       Cluster      Cluster          up   9000  auto/10000 healthy  false
    e0b       Cluster      Cluster          up   9000  auto/10000 healthy  false
    Node: node2
        Ignore
  11. Verify that both nodes each have one connection to each switch:
    Show example
    The following example shows the appropriate results for both switches:
    node1      /cdp
                e0a    cs1 (b8:ce:f6:19:1b:42)   Ethernet1/1/1   N9K-C9336C-FX2
                e0b    cs2 (b8:ce:f6:19:1b:96)   Ethernet1/1/2   N9K-C9336C-FX2
    node2      /cdp
Step 3: Verify the configuration
  1. Enable auto-revert on the cluster LIFs:
    cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert true
  2. On switch cs2, shut down and restart all cluster ports to trigger an auto-revert of all cluster LIFs that are not on their home ports.
    cs2> enable
    cs2# configure
    cs2(config)# interface eth1/1-1/2
    cs2(config-if-range)# shutdown
    (Wait for 5-10 seconds before re-enabling the ports)
    cs2(config-if-range)# no shutdown
    (After executing the no shutdown command, the nodes detect the change and begin to auto-revert the cluster LIFs to their home ports)
    cs2(config-if-range)# exit
    cs2(config)# exit
    cs2#
  3. Verify that the cluster LIFs have reverted to their home ports (this might take a minute):
    If any of the cluster LIFs have not reverted to their home port, manually revert them. You must connect to each node-mgmt LIF or SP/BMC system console of the local node that owns the LIF:
    network interface revert -vserver Cluster -lif *
  4. Verify that the cluster is healthy:
    cluster show
  5. Verify the connectivity of the remote cluster interfaces:
Note Wait for a number of seconds before running the show command to display the details.
node1
       3/5/2022 19:21:18 -06:00   node1_clus2      node2_clus1      none
node2
All ONTAP releases
cluster1::*> cluster ping-cluster -node node2
Host is node2
Cluster node1_clus1 169.254.209.69 node1     e0a
Cluster node1_clus2 169.254.49.125 node1     e0b
Cluster node2_clus1 169.254.47.194 node2     e0a
Cluster node2_clus2 169.254.19.183 node2     e0b
Ping status:
RPC status:
  1. Change the privilege level back to admin:
    set -privilege admin
  2. If you suppressed automatic case creation, re-enable it by invoking an AutoSupport message:
What's next?
After you've migrated your switches, you can configure switch health monitoring.
