Configure SNMPv3 for Ethernet switch health monitoring
Configure SNMPv3 on your network switches to enable secure, authenticated communication with the Ethernet switch health monitor (CSHM). SNMPv3 provides encrypted polling of switch status for health monitoring in ONTAP.
The Ethernet Switch Health Monitor (CSHM) utilizes SNMP to monitor the health and performance of network switches. By default, SNMPv2c is configured automatically through the Reference Configuration File (RCF). SNMPv3 is more secure than SNMPv2 because it introduces robust security features such as authentication, encryption, and message integrity, which protect against unauthorized access and ensure data confidentiality and integrity during transmission.
The following commands are used to configure an SNMPv3 username on Broadcom, Cisco, and NVIDIA switches:
Configure an SNMPv3 username NETWORK-OPERATOR on Broadcom BES-53248 switches.
Beginning with ONTAP 9.20.1, you can configure SHA-512 authentication on Broadcom switches. |
For no authentication:
snmp-server user <snmpv3-user> NETWORK-OPERATOR noauth -
For MD5/SHA/SHA-512 authentication:
snmp-server user <snmpv3-user> NETWORK-OPERATOR [auth-md5|auth-sha|auth-sha512] -
For MD5/SHA/SHA-512 authentication with AES/DES encryption:
snmp-server user <snmpv3-user> NETWORK-OPERATOR [auth-md5|auth-sha|auth-sha512] [priv-aes128|priv-des]
The following command configures an SNMPv3 username on the ONTAP side:
security login create -user-or-group-name <snmpv3-user> -application snmp -authentication-method usm -remote-switch-ipaddress <address>
The following command establishes the SNMPv3 username with CSHM:
cluster1::*> system switch ethernet modify -device <switch-name> -snmp-version SNMPv3 -community-or-username <snmpv3-user>
Set up the SNMPv3 user on the switch to use SHA authentication and AES-128 encryption:
(sw1)(Config)# snmp-server user SNMPv3shaAes128 NETWORK-OPERATOR auth-sha priv-aes128 (sw1)(Config)# show snmp user snmp SNMPv3shaAes128 Name Group Name Auth Priv Meth Meth Remote Engine ID Remote IP Address ----------------- ------------------ ------- ------ -------------------------------- ------------------------- SNMPv3shaAes128 NETWORK-OPERATOR SHA AES128 800XXXXXXXXXXXXXXXXXX1 -
Set up the SNMPv3 user on the ONTAP side:
cluster1::*> security login create -user-or-group-name SNMPv3shaAes128 -application snmp -authentication-method usm -remote-switch-ipaddress 192.0.2.10 Enter the authoritative entity's EngineID [remote EngineID]: Which authentication protocol do you want to choose (none, md5, sha, sha2-256, sha512) [none]: sha Enter the authentication protocol password (minimum 8 characters long): Enter the authentication protocol password again: Which privacy protocol do you want to choose (none, des, aes128) [none]: aes128 Enter privacy protocol password (minimum 8 characters long): Enter privacy protocol password again:
Configure CSHM to monitor with the new SNMPv3 user:
cluster1::*> system switch ethernet modify -device "sw1" -snmp-version SNMPv3 -community-or-username SNMPv3shaAes128
After waiting the CSHM polling period, verify that "Reason For Not Monitoring" is set to "None".
cluster1::*> system switch ethernet polling-interval show Polling Interval (in minutes): 5 cluster1::*> system switch ethernet show-all -device "sw1" -instance Device Name: sw1 IP Address: 192.0.2.10 SNMP Version: SNMPv3 Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: SNMPv3shaAes128 Model Number: BES-53248 Switch Network: cluster-network Software Version: 3.14.1.1 Reason For Not Monitoring: None <---- should display this if SNMP settings are valid Source Of Switch Version: CDP/ISDP Is Monitored ?: true Serial Number of the Device: QTFXXXXXXXXXC RCF Version: RCF BES-53248 v1.14a 1-CLUSTER
Configure an SNMPv3 username <snmpv3-user> on Cisco Nexus switches.
Beginning with ONTAP 9.20.1, you can configure SHA-512 or SHA-256 authentication on Cisco switches. |
snmp-server user <snmpv3-user> NoAuth -
For MD5/SHA/SHA-256/SHA-512 authentication:
snmp-server user <snmpv3-user> auth [md5|sha|sha-256|sha-512] <auth-password> -
For MD5/SHA/SHA-256/SHA-512 authentication with AES/DES encryption:
snmp-server user <snmpv3-user> AuthEncrypt auth [md5|sha|sha-256|sha-512] <auth-password> priv [aes-128|des] <priv-password>
(sw1)(Config)# snmp-server user SNMPv3shaAes128 auth sha <auth_password> priv aes-128 <priv_password> (sw1)(Config)# show snmp use SNMPv3shaAes128 User Auth Priv(enforce) Groups Auth Mode acl_filter _ _ __ SNMPv3shaAes128 sha aes-128(no) network-operator Local (sw1)(Config)#
cluster1::*> system switch ethernet polling-interval show Polling Interval (in minutes): 5 cluster1::*> system switch ethernet show-all -device "sw1" -instance Device Name: sw1 IP Address: 192.0.2.10 SNMP Version: SNMPv3 Is Discovered: true SNMPv2c Community String or SNMPv3 Username: SNMPv3shaAes128 Model Number: N9K-C9336C-FX2 Switch Network: cluster-network Software Version: Cisco NX-OS(tm) Nexus9000 C9336C-FX2, Software (NXOS 64-bit), Version 10.2(4), RELEASE SOFTWARE Copyright (c) 2002-2022 by Cisco Systems, Inc. Compiled 9/20/2022 12:00:00 Reason For Not Monitoring: None <---- should display this if SNMP settings are valid Source Of Switch Version: CDP/ISDP Is Monitored ?: true Serial Number of the Device: FDOXXXXXXX1 RCF Version: RCF NX9336C-FX2 v1.14 1-CLUSTER 2-STORAGE
Configure an SNMPv3 username <snmpv3-user> on NVIDIA Cumulus switches running CL 5.4.0:
nv set service snmp-server username <snmpv3-user> auth-none -
For MD5/SHA authentication:
nv set service snmp-server username <snmpv3-user> [auth-md5|auth-sha] <auth-password> -
For MD5/SHA authentication with AES/DES encryption:
nv set service snmp-server username <snmpv3-user> [auth-md5|auth-sha] <auth-password> [encrypt-aes|encrypt-des] <priv-password>
cumulus@sw1:~$ net show snmp status Simple Network Management Protocol (SNMP) Daemon. --------------------------------- ---------------- Current Status active (running) Reload Status enabled Listening IP Addresses all vrf mgmt Main snmpd PID 4318 Version 1 and 2c Community String Configured Version 3 Usernames Not Configured --------------------------------- ---------------- cumulus@sw1:~$ cumulus@sw1:~$ net add snmp-server username SNMPv3shaAes128 auth-sha <auth-password> encrypt-aes <priv-password> cumulus@sw1:~$ net commit --- /etc/snmp/snmpd.conf 2020-08-02 21:09:34.686949282 +0000 +++ /run/nclu/snmp/snmpd.conf 2020-08-11 00:13:51.826126655 +0000 @@ -1,26 +1,28 @@ # Auto-generated config file: do not edit. # agentaddress udp:@mgmt:161 agentxperms 777 777 snmp snmp agentxsocket /var/agentx/master createuser _snmptrapusernameX +createuser SNMPv3shaAes128 SHA <auth-password> AES <priv-password> ifmib_max_num_ifaces 500 iquerysecname _snmptrapusernameX master agentx monitor -r 60 -o laNames -o laErrMessage "laTable" laErrorFlag != 0 pass -p 10 1.3.6.1.2.1.1.1 /usr/share/snmp/sysDescr_pass.py pass_persist 1.2.840.10006.300.43 /usr/share/snmp/ieee8023_lag_pp.py pass_persist 1.3.6.1.2.1.17 /usr/share/snmp/bridge_pp.py pass_persist 1.3.6.1.2.1.31.1.1.1.18 /usr/share/snmp/snmpifAlias_pp.py pass_persist 1.3.6.1.2.1.47 /usr/share/snmp/entity_pp.py pass_persist 1.3.6.1.2.1.99 /usr/share/snmp/entity_sensor_pp.py pass_persist 1.3.6.1.4.1.40310.1 /usr/share/snmp/resq_pp.py pass_persist 1.3.6.1.4.1.40310.2 /usr/share/snmp/cl_drop_cntrs_pp.py pass_persist 1.3.6.1.4.1.40310.3 /usr/share/snmp/cl_poe_pp.py pass_persist 1.3.6.1.4.1.40310.4 /usr/share/snmp/bgpun_pp.py pass_persist 1.3.6.1.4.1.40310.5 /usr/share/snmp/cumulus-status.py pass_persist 1.3.6.1.4.1.40310.6 /usr/share/snmp/cumulus-sensor.py pass_persist 1.3.6.1.4.1.40310.7 /usr/share/snmp/vrf_bgpun_pp.py +rocommunity cshm1! default rouser _snmptrapusernameX +rouser SNMPv3shaAes128 priv sysobjectid 1.3.6.1.4.1.40310 sysservices 72 -rocommunity cshm1! default net add/del commands since the last "net commit" User Timestamp Command --------------- -------------------------- ------------------------------------------------------------------------- SNMPv3shaAes128 2020-08-11 00:13:51.826987 net add snmp-server username SNMPv3shaAes128 auth-sha <auth-password> encrypt-aes <priv-password> cumulus@sw1:~$ cumulus@sw1:~$ net show snmp status Simple Network Management Protocol (SNMP) Daemon. --------------------------------- ---------------- Current Status active (running) Reload Status enabled Listening IP Addresses all vrf mgmt Main snmpd PID 24253 Version 1 and 2c Community String Configured Version 3 Usernames Configured <---- Configured here --------------------------------- ---------------- cumulus@sw1:~$
cluster1::*> system switch ethernet polling-interval show Polling Interval (in minutes): 5 cluster1::*> system switch ethernet show-all -device "sw1" -instance Device Name: sw1 IP Address: 192.0.2.10 SNMP Version: SNMPv3 Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: SNMPv3shaAes128 Model Number: MSN2100-CB2FC Switch Network: cluster-network Software Version: Cumulus Linux version 5.4.0 running on Mellanox Technologies Ltd. MSN2100 Reason For Not Monitoring: None <---- should display this if SNMP settings are valid Source Of Switch Version: LLDP Is Monitored ?: true Serial Number of the Device: MT2110X06399 RCF Version: RCF MSN2100 v1.14 1-CLUSTER
Configure an SNMPv3 username <snmpv3-user> on NVIDIA Cumulus switches running CLI 5.11.0 and later:
nv set system snmp-server username <snmpv3-user> auth-none -
nv set system snmp-server username <snmpv3-user> [auth-md5|auth-sha] <auth-password> -
nv set system snmp-server username <snmpv3-user> [auth-md5|auth-sha] <auth-password> [encrypt-aes|encrypt-des] <priv-password>
cumulus@sw1:~$ nv set system snmp-server username SNMPv3shaAes128 auth-sha <auth-password> encrypt-aes <priv-password> created [rev_id: 14] cumulus@sw1:~$ nv config apply applied_and_saved [rev_id: 14] cumulus@sw1:~$ nv show system snmp-server username SNMPv3shaAes128 applied ---------- --------------------------------------- [auth-sha] $nvsec$836XXXXXXXXXXXXXXXXXXXXXXXXXXXXX -
cluster1::*> system switch ethernet polling-interval show Polling Interval (in minutes): 5 cluster1::*> system switch ethernet show-all -device "sw1" -instance Device Name: sw1 IP Address: 192.0.2.10 SNMP Version: SNMPv3 Is Discovered: true DEPRECATED-Community String or SNMPv3 Username: - Community String or SNMPv3 Username: SNMPv3shaAes128 Model Number: MSN2100-CB2FC Switch Network: cluster-network Software Version: Cumulus Linux version 5.11.0 running on Mellanox Technologies Ltd. MSN2100 Reason For Not Monitoring: None <---- should display this if SNMP settings are valid Source Of Switch Version: LLDP Is Monitored ?: true Serial Number of the Device: MT2110X06399 RCF Version: RCF MSN2100 v1.14 1-CLUSTER
