Install and maintain
Configure Cisco Nexus 9336C-FX2 shared switches
Contributors netapp-yvonneo netapp-jolieg netapp-jsnyder
Configure Cisco Nexus 9336C-FX2 shared switches to prepare them for combined cluster and storage network operation.
Before you begin
Make sure you have the following:
Steps
  1. Perform an initial configuration of the switches.
    For configuration, you need the appropriate number and type of cables and cable connectors for your switches.
    Depending on the type of switch you are initially configuring, you need to connect to the switch console port with the included console cable; you also need to provide specific network information.
  2. Boot the switch.
    Provide the applicable responses to the following initial setup questions when you first boot the switch.
    Your site's security policy defines the responses and services to enable.
    1. Abort Auto Provisioning and continue with normal setup? (yes/no)
      Respond with yes. The default is no.
    2. Do you want to enforce secure password standard? (yes/no)
      Respond with yes. The default is yes.
    3. Enter the password for admin.
      The default password is admin; you must create a new, strong password.
      A weak password can be rejected.
    4. Would you like to enter the basic configuration dialog? (yes/no)
      Respond with yes at the initial configuration of the switch.
    5. Create another login account? (yes/no)
      Your answer depends on your site's policies on alternate administrators. The default is no.
    6. Configure read-only SNMP community string? (yes/no)
      Respond with no. The default is no.
    7. Configure read-write SNMP community string? (yes/no)
    8. Enter the switch name.
      The switch name is limited to 63 alphanumeric characters.
    9. Continue with out-of-band (mgmt0) management configuration? (yes/no)
      Respond with yes (the default) at that prompt. At the mgmt0 IPv4 address: prompt, enter your IP address: ip_address
    10. Configure the default-gateway? (yes/no)
      Respond with yes. At the IPv4 address of the default-gateway: prompt, enter your default_gateway.
    11. Configure advanced IP options? (yes/no)
    12. Enable the telnet service? (yes/no)
    13. Enable SSH service? (yes/no)
      Note SSH is recommended when using Ethernet Switch Health Monitor (CSHM) for its log collection features. SSHv2 is also recommended for enhanced security.
    14. Enter the type of SSH key you want to generate (dsa/rsa/rsa1). The default is rsa.
    15. Enter the number of key bits (1024- 2048).
    16. Configure the NTP server? (yes/no)
    17. Configure default interface layer (L3/L2):
      Respond with L2. The default is L2.
    18. Configure default switch port interface state (shut/noshut):
      Respond with noshut. The default is noshut.
    19. Configure CoPP system profile (strict/moderate/lenient/dense):
      Respond with strict. The default is strict.
    20. Would you like to edit the configuration? (yes/no)
      You should see the new configuration at this point. Review and make any necessary changes to the configuration you just entered. Respond with no at the prompt if you are satisfied with the configuration. Respond with yes if you want to edit your configuration settings.
    21. Use this configuration and save it? (yes/no)
      Respond with yes to save the configuration. This automatically updates the kickstart and system images.
  3. Verify the configuration choices you made in the display that appears at the end of the setup, and make sure that you save the configuration.
    Note If you do not save the configuration at this stage, none of the changes will be in effect the next time you reboot the switch.
  4. Check the version on the cluster network switches, and if necessary, download the
    NetApp-supported version of the software to the switches from the Cisco software download page.
What's next?
After you've configured your switches, you can prepare to install NX-OS and RCF.
