Review documentation requirements for Cisco Nexus 9336C-FX2 shared switches
Review the switch and controller documentation required to set up Cisco Nexus 9336C-FX2 shared switches and configure them in an ONTAP environment.
To set up the Cisco Nexus 9336C-FX2 shared switches, refer to Cisco Nexus 9000 Series Switches Support.
| Document title | Description |
Provides detailed information about site requirements, switch hardware details, and installation options. |
Cisco Nexus 9000 Series Switch Software Configuration Guides (choose the guide for the NX-OS release installed on your switches) |
Provides initial switch configuration information that you need before you can configure the switch for ONTAP operation. |
Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide (choose the guide for the NX-OS release installed on your switches) |
Provides information on how to downgrade the switch to ONTAP supported switch software, if necessary. |
Cisco Nexus 9000 Series NX-OS Command Reference Master Index |
Provides links to the various command references provided by Cisco. |
Describes the Management Information Base (MIB) files for the Nexus 9000 switches. |
Describes the system messages for Cisco Nexus 9000 series switches, those that are informational, and others that might help diagnose problems with links, internal hardware, or the system software. |
Cisco Nexus 9000 Series NX-OS Release Notes (choose the notes for the NX-OS release installed on your switches) |
Describes the features, bugs, and limitations for the Cisco Nexus 9000 Series. |
Regulatory Compliance and Safety Information for Cisco Nexus 9000 Series |
Provides international agency compliance, safety, and statutory information for the Nexus 9000 series switches. |
