Install and maintain
Review documentation requirements for Cisco Nexus 92300YC cluster switches
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Review the switch and controller documentation required to set up Cisco Nexus 92300YC cluster switches and configure them in an ONTAP cluster.
Switch documentation
To set up the Cisco Nexus 92300YC switches, you need the following documentation from Cisco Nexus 9000 Series Switches Support.
Document title Description
Nexus 9000 Series Hardware Installation Guide
Provides detailed information about site requirements, switch hardware details, and installation options.
Cisco Nexus 9000 Series Switch Software Configuration Guides (choose the guide for the NX-OS release installed on your switches)
Provides initial switch configuration information that you need before you can configure the switch for ONTAP operation.
Cisco Nexus 9000 Series NX-OS Software Upgrade and Downgrade Guide (choose the guide for the NX-OS release installed on your switches)
Provides information on how to downgrade the switch to ONTAP supported switch software, if necessary.
Cisco Nexus 9000 Series NX-OS Command Reference Master Index
Provides links to the various command references provided by Cisco.
Cisco Nexus 9000 MIBs Reference
Describes the Management Information Base (MIB) files for the Nexus 9000 switches.
Nexus 9000 Series NX-OS System Message Reference
Describes the system messages for Cisco Nexus 9000 series switches, those that are informational, and others that might help diagnose problems with links, internal hardware, or the system software.
Cisco Nexus 9000 Series NX-OS Release Notes (choose the notes for the NX-OS release installed on your switches)
Describes the features, bugs, and limitations for the Cisco Nexus 9000 Series.
Regulatory Compliance and Safety Information for Cisco Nexus 9000 Series
Provides international agency compliance, safety, and statutory information for the Nexus 9000 series switches.
ONTAP systems documentation
To set up an ONTAP system, you need the following documents for your version of the operating system.
Name Description
Controller-specific Installation and Setup Instructions
Describes how to install NetApp hardware.
Provides detailed information about all aspects of the ONTAP releases.
Provides NetApp hardware configuration and compatibility information.
Rail kit and cabinet documentation
To install a Cisco Nexus 92300YC switch in a NetApp cabinet, refer to the following hardware documentation.
Name Description
Describes the FRUs associated with the 42U system cabinet, and provides maintenance and FRU replacement instructions.
Describes how to install a Cisco Nexus 92300YC switch in a four-post NetApp cabinet.
