Install Cumulus Linux in Cumulus mode on NVIDIA SN2100 storage switches
Install Cumulus Linux (CL) on NVIDIA SN2100 storage switches when the switch is running in Cumulus mode.
Cumulus Linux (CL) OS can be installed either when the switch is running Cumulus Linux or ONIE (refer to Install in ONIE mode). |
Make sure that the following are available:
Intermediate-level Linux knowledge.
Familiarity with basic text editing, UNIX file permissions, and process monitoring. A variety of text editors are pre-installed, including
viandnano. -
Access to a Linux or UNIX shell. If you are running Windows, use a Linux environment as your command line tool for interacting with Cumulus Linux.
The baud rate requirement must be set to 115200 on the serial console switch for NVIDIA SN2100 switch console access, as follows:
115200 baud
8 data bits
1 stop bit
parity: none
flow control: none
Be aware of the following:
Each time Cumulus Linux is installed, the entire file system structure is erased and rebuilt. |
The default password for the cumulus user account is cumulus. The first time you log into Cumulus Linux, you must change this default password. Be sure to update any automation scripts before installing a new image. Cumulus Linux provides command line options to change the default password automatically during the installation process. |
Log in to the switch.
First time log in to the switch requires username/password of cumulus/cumulus with
sudoprivileges.cumulus login: cumulus Password: cumulus You are required to change your password immediately (administrator enforced) Changing password for cumulus. Current password: cumulus New password: <new_password> Retype new password: <new_password>
Check the Cumulus Linux version:
net show systemcumulus@cumulus:mgmt:~$ net show system Hostname......... cumulus Build............ Cumulus Linux 4.4.3 Uptime........... 0:08:20.860000 Model............ Mlnx X86 CPU.............. x86_64 Intel Atom C2558 2.40GHz Memory........... 8GB Disk............. 14.7GB ASIC............. Mellanox Spectrum MT52132 Ports............ 16 x 100G-QSFP28 Part Number...... MSN2100-CB2FC Serial Number.... MT2105T05177 Platform Name.... x86_64-mlnx_x86-r0 Product Name..... MSN2100 ONIE Version..... 2019.11-5.2.0020-115200 Base MAC Address. 04:3F:72:43:92:80 Manufacturer..... Mellanox
Configure the hostname, IP address, subnet mask, and default gateway. The new hostname only becomes effective after restarting the console/SSH session.
A Cumulus Linux switch provides at least one dedicated Ethernet management port called eth0. This interface is specifically for out-of-band management use. By default, the management interface uses DHCPv4 for addressing.Do not use an underscore (_), apostrophe ('), or non-ASCII characters in the hostname. cumulus@cumulus:mgmt:~$ net add hostname sw1 cumulus@cumulus:mgmt:~$ net add interface eth0 ip address 10.233.204.71 cumulus@cumulus:mgmt:~$ net add interface eth0 ip gateway 10.233.204.1 cumulus@cumulus:mgmt:~$ net pending cumulus@cumulus:mgmt:~$ net commit
This command modifies both the
/etc/hostnameand/etc/hostsfiles. -
Confirm that the hostname, IP address, subnet mask, and default gateway have been updated.
cumulus@sw1:mgmt:~$ hostname sw1 cumulus@sw1:mgmt:~$ ifconfig eth0 eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.233.204.71 netmask 255.255.254.0 broadcast 10.233.205.255 inet6 fe80::bace:f6ff:fe19:1df6 prefixlen 64 scopeid 0x20<link> ether b8:ce:f6:19:1d:f6 txqueuelen 1000 (Ethernet) RX packets 75364 bytes 23013528 (21.9 MiB) RX errors 0 dropped 7 overruns 0 frame 0 TX packets 4053 bytes 827280 (807.8 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device memory 0xdfc00000-dfc1ffff cumulus@sw1::mgmt:~$ ip route show vrf mgmt default via 10.233.204.1 dev eth0 unreachable default metric 4278198272 10.233.204.0/23 dev eth0 proto kernel scope link src 10.233.204.71 127.0.0.0/8 dev mgmt proto kernel scope link src 127.0.0.1
Set the date, time, time zone, and NTP server on the switch.
Verify the current time zone:
cumulus@sw1:~$ cat /etc/timezone
Update to the new time zone:
cumulus@sw1:~$ sudo dpkg-reconfigure --frontend noninteractive tzdata
Verify your current time zone:
cumulus@switch:~$ date +%Z
To set the time zone using the guided wizard, run the following command:
cumulus@sw1:~$ sudo dpkg-reconfigure tzdata
Set the software clock according to the configured time zone:
cumulus@switch:~$ sudo date -s "Tue Oct 28 00:37:13 2023"
Set the current value of the software clock to the hardware clock:
cumulus@switch:~$ sudo hwclock -w
Add an NTP server if required:
cumulus@sw1:~$ net add time ntp server <cumulus.network.ntp.org> iburst cumulus@sw1:~$ net pending cumulus@sw1:~$ net commit
Verify that
ntpdis running on the system:cumulus@sw1:~$ ps -ef | grep ntp ntp 4074 1 0 Jun20 ? 00:00:33 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -u 101:102
Specify the NTP source interface. By default, the source interface that NTP uses is
eth0. You can configure a different NTP source interface as follows:cumulus@sw1:~$ net add time ntp source <src_int> cumulus@sw1:~$ net pending cumulus@sw1:~$ net commit
Install Cumulus Linux 4.4.3:
cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-4.4.3-mlx-amd64.bin
The installer starts the download. Type y when prompted.
Reboot the NVIDIA SN2100 switch:
cumulus@sw1:mgmt:~$ sudo reboot
The installation starts automatically, and the following GRUB screen choices appear. Do not make any selections.
Cumulus-Linux GNU/Linux
ONIE: Install OS
CUMULUS-INSTALL
Repeat steps 1 to 4 to log in.
Verify that the Cumulus Linux version is 4.4.3:
net show versioncumulus@sw1:mgmt:~$ net show version NCLU_VERSION=1.0-cl4.4.3u0 DISTRIB_ID="Cumulus Linux" DISTRIB_RELEASE=4.4.3 DISTRIB_DESCRIPTION="Cumulus Linux 4.4.3"
Create a new user and add this user to the
sudogroup. This user only becomes effective after the console/SSH session is restarted.sudo adduser --ingroup netedit admincumulus@sw1:mgmt:~$ sudo adduser --ingroup netedit admin [sudo] password for cumulus: Adding user 'admin' ... Adding new user 'admin' (1001) with group `netedit' ... Creating home directory '/home/admin' ... Copying files from '/etc/skel' ... New password: Retype new password: passwd: password updated successfully Changing the user information for admin Enter the new value, or press ENTER for the default Full Name []: Room Number []: Work Phone []: Home Phone []: Other []: Is the information correct? [Y/n] y cumulus@sw1:mgmt:~$ sudo adduser admin sudo [sudo] password for cumulus: Adding user `admin' to group `sudo' ... Adding user admin to group sudo Done. cumulus@sw1:mgmt:~$ exit logout Connection to 10.233.204.71 closed. [admin@cycrh6svl01 ~]$ ssh admin@10.233.204.71 admin@10.233.204.71's password: Linux sw1 4.19.0-cl-1-amd64 #1 SMP Cumulus 4.19.206-1+cl4.4.1u1 (2021-09-09) x86_64 Welcome to NVIDIA Cumulus (R) Linux (R) For support and online technical documentation, visit http://www.cumulusnetworks.com/support The registered trademark Linux (R) is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis. admin@sw1:mgmt:~$
nv show systemcumulus@cumulus:mgmt:~$ nv show system operational applied description ------------------- -------------------- --------------------- hostname cumulus cumulus build Cumulus Linux 5.3.0 system build version uptime 6 days, 8:37:36 system uptime timezone Etc/UTC system time zone
A Cumulus Linux switch provides at least one dedicated Ethernet management port called eth0. This interface is specifically for out-of-band management use. By default, the management interface uses DHCPv4 for addressing.Do not use an underscore (_), apostrophe ('), or non-ASCII characters in the hostname. cumulus@cumulus:mgmt:~$ nv set system hostname sw1 cumulus@cumulus:mgmt:~$ nv set interface eth0 ip address 10.233.204.71/24 cumulus@cumulus:mgmt:~$ nv set interface eth0 ip gateway 10.233.204.1 cumulus@cumulus:mgmt:~$ nv config apply cumulus@cumulus:mgmt:~$ nv config save
Set the time zone, date, time, and NTP server on the switch.
Set the time zone:
cumulus@sw1:~$ nv set system timezone US/Eastern cumulus@sw1:~$ nv config apply
cumulus@sw1:~$ sudo date -s "Tue Oct 28 00:37:13 2023"
cumulus@sw1:~$ sudo hwclock -w
cumulus@sw1:~$ nv set service ntp mgmt listen eth0 cumulus@sw1:~$ nv set service ntp mgmt server <server> iburst on cumulus@sw1:~$ nv config apply cumulus@sw1:~$ nv config save
Refer to the Knowledge Base article NTP server configuration is not working with NVIDIA SN2100 switches for further details.
Verify that
eth0. You can configure a different NTP source interface as follows:cumulus@sw1:~$ nv set service ntp default listen <src_int> cumulus@sw1:~$ nv config apply
Install Cumulus Linux 5.4.0:
cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-5.4-mlx-amd64.bin
ONIE: Install OS
CUMULUS-INSTALL
Verify that the Cumulus Linux version is 5.4.0:
nv show systemcumulus@cumulus:mgmt:~$ nv show system operational applied description ------------------- -------------------- --------------------- hostname cumulus cumulus build Cumulus Linux 5.4.0 system build version uptime 6 days, 13:37:36 system uptime timezone Etc/UTC system time zone
Verify that the nodes each have a connection to each switch:
cumulus@sw1:mgmt:~$ net show lldp LocalPort Speed Mode RemoteHost RemotePort --------- ----- ---------- ---------------------------------- ----------- eth0 100M Mgmt mgmt-sw1 Eth110/1/29 swp2s1 25G Trunk/L2 node1 e0a swp15 100G BondMember sw2 swp15 swp16 100G BondMember sw2 swp16
Add additional user groups for the admin user to access
nvcommands:cumulus@sw1:mgmt:~$ sudo adduser admin nvshow [sudo] password for cumulus: Adding user 'admin' to group 'nvshow' ... Adding user admin to group nvshow Done.Refer to NVIDIA User Accounts for more information.
When you log in to the switch for the first time, it requires the username/password of cumulus/cumulus with
nv show systemcumulus@cumulus:mgmt:~$ nv show system operational applied description ------------------- -------------------- --------------------- hostname cumulus cumulus build Cumulus Linux 5.4.0 system build version uptime 6 days, 8:37:36 system uptime timezone Etc/UTC system time zone
A Cumulus Linux switch provides at least one dedicated Ethernet management port called eth0. This interface is specifically for out-of-band management use. By default, the management interface uses DHCPv4 for addressing.Do not use an underscore (_), apostrophe ('), or non-ASCII characters in the hostname. cumulus@cumulus:mgmt:~$ nv unset interface eth0 ip address dhcp cumulus@cumulus:mgmt:~$ nv set interface eth0 ip address 10.233.204.71/24 cumulus@cumulus:mgmt:~$ nv set interface eth0 ip gateway 10.233.204.1 cumulus@cumulus:mgmt:~$ nv config apply cumulus@cumulus:mgmt:~$ nv config save
Set the time zone:
Verify that
Install Cumulus Linux 5.11.0:
cumulus@sw1:mgmt:~$ sudo onie-install -a -i http://<web-server>/<path>/cumulus-linux-5.11.0-mlx-amd64.bin
ONIE: Install OS
CUMULUS-INSTALL
Verify that the Cumulus Linux version is 5.11.0:
nv show systemcumulus@cumulus:mgmt:~$ nv show system operational applied description ------------------- ---------------------- --------------------- build Cumulus Linux 5.11.0 uptime 153 days, 2:44:16 hostname cumulus cumulus product-name Cumulus Linux product-release 5.11.0 platform x86_64-mlnx_x86-r0 system-memory 2.76 GB used / 2.28 GB free / 7.47 GB total swap-memory 0 Bytes used / 0 Bytes free / 0 Bytes total health-status not OK date-time 2025-04-23 09:55:24 status N/A timezone Etc/UTC maintenance mode disabled ports enabled version kernel 6.1.0-cl-1-amd64 build-date Thu Nov 14 13:06:38 UTC 2024 image 5.11.0 onie 2019.11-5.2.0020-115200
Verify that each node has a connection to each switch:
cumulus@sw1:mgmt:~$ nv show interface lldp LocalPort Speed Mode RemoteHost RemotePort --------- ----- ---------- ---------------------------------- ----------- eth0 100M eth mgmt-sw1 Eth110/1/14 swp2s1 25G Trunk/L2 node1 e0a swp1s1 10G swp sw2 e0a swp9 100G swp sw3 e4a swp10 100G swp sw4 e4a swp15 100G swp sw5 swp15 swp16 100G swp sw6 swp16
After you've installed Cumulus Linux in Cumulus mode, you can install or upgrade the RCF script.
