Install Cumulus Linux in ONIE mode on NVIDIA SN2100 storage switches
Install Cumulus Linux (CL) on NVIDIA SN2100 storage switches when the switch is running in ONIE mode.
Cumulus Linux (CL) OS can be installed either when the switch is running Cumulus Linux or ONIE (refer to Install in Cumulus mode). |
You can install the Cumulus Linux using Open Network Install Environment (ONIE) that allows for automatic discovery of a network installer image. This facilitates the system model of securing switches with an operating system choice, such as Cumulus Linux. The easiest way to install Cumulus Linux with ONIE is with local HTTP discovery.
If your host is IPv6-enabled, make sure it is running a web server. If your host is IPv4-enabled, make sure it is running DHCP in addition to a web server. |
This procedure demonstrates how to upgrade Cumulus Linux after the admin has booted in ONIE.
Download the Cumulus Linux installation file to the root directory of the web server. Rename this file
onie-installer. -
Connect your host to the management Ethernet port of the switch using an Ethernet cable.
Power on the switch. The switch downloads the ONIE image installer and boots. After the installation completes, the Cumulus Linux login prompt appears in the terminal window.
Each time Cumulus Linux is installed, the entire file system structure is erased and rebuilt. -
Reboot the SN2100 switch:
cumulus@cumulus:mgmt:~$ sudo reboot
Press the Esc key at the GNU GRUB screen to interrupt the normal boot process, select ONIE and press Enter.
On the next screen displayed, select ONIE: Install OS.
The ONIE installer discovery process runs searching for the automatic installation. Press Enter to temporarily stop the process.
When the discovery process has stopped:
ONIE:/ # onie-stop discover: installer mode detected. Stopping: discover...start-stop-daemon: warning: killing process 427: No such process done.
If the DHCP service is running on your network, verify that the IP address, subnet mask, and the default gateway are correctly assigned:
ifconfig eth0Show example
ONIE:/ # ifconfig eth0 eth0 Link encap:Ethernet HWaddr B8:CE:F6:19:1D:F6 inet addr:10.233.204.71 Bcast:10.233.205.255 Mask:255.255.254.0 inet6 addr: fe80::bace:f6ff:fe19:1df6/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:21344 errors:0 dropped:2135 overruns:0 frame:0 TX packets:3500 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:6119398 (5.8 MiB) TX bytes:472975 (461.8 KiB) Memory:dfc00000-dfc1ffff ONIE:/ # route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 10.233.204.1 0.0.0.0 UG 0 0 0 eth0 10.233.204.0 * 255.255.254.0 U 0 0 0 eth0 -
If the IP addressing scheme is manually defined, do the following:
ONIE:/ # ifconfig eth0 10.233.204.71 netmask 255.255.254.0 ONIE:/ # route add default gw 10.233.204.1
Repeat step 9 to verify that the static information is correctly entered.
Install Cumulus Linux:
ONIE:/ # route Kernel IP routing table ONIE:/ # onie-nos-install http://<web-server>/<path>/cumulus-linux-4.4.3-mlx-amd64.bin Stopping: discover... done. Info: Attempting http://10.60.132.97/x/eng/testbedN,svl/nic/files/cumulus-linux-4.4.3-mlx-amd64.bin ... Connecting to 10.60.132.97 (10.60.132.97:80) installer 100% |*| 552M 0:00:00 ETA ... ...
Once the installation has completed, log in to the switch:
Show example
cumulus login: cumulus Password: cumulus You are required to change your password immediately (administrator enforced) Changing password for cumulus. Current password: cumulus New password: <new_password> Retype new password: <new_password>
Verify the Cumulus Linux version:
net show versionShow example
cumulus@cumulus:mgmt:~$ net show version NCLU_VERSION=1.0-cl4.4.3u4 DISTRIB_ID="Cumulus Linux" DISTRIB_RELEASE=4.4.3 DISTRIB_DESCRIPTION="Cumulus Linux 4.4.3”
After you've installed Cumulus Linux in ONIE mode, you can install or upgrade the RCF script.
