Install and maintain
Prepare for migration from Nexus 5596 switches to Nexus 3232C switches
Contributors netapp-yvonneo
Follow these steps to prepare your Cisco Nexus 5596 switches for migration to Cisco Nexus 3232C switches.
Steps
  1. If AutoSupport is enabled on this cluster, suppress automatic case creation by invoking an AutoSupport message:
    system node autosupport invoke -node * -type all - message MAINT=xh
    x is the duration of the maintenance window in hours.
    Note
    The AutoSupport message notifies technical support of this maintenance task so that automatic case creation is suppressed during the maintenance window.
  2. Display information about the devices in your configuration:
    network device-discovery show
    Show example
    The following example shows how many cluster interconnect interfaces have been configured in each node for each cluster interconnect switch:
    cluster::> network device-discovery show
                Local  Discovered
    Node        Port   Device              Interface        Platform
    n1         /cdp
                e0a    CL1                 Ethernet1/1      N5K-C5596UP
                e0b    CL2                 Ethernet1/1      N5K-C5596UP
                e0c    CL2                 Ethernet1/2      N5K-C5596UP
                e0d    CL1                 Ethernet1/2      N5K-C5596UP
    n2         /cdp
                e0a    CL1                 Ethernet1/3      N5K-C5596UP
                e0b    CL2                 Ethernet1/3      N5K-C5596UP
                e0c    CL2                 Ethernet1/4      N5K-C5596UP
                e0d    CL1                 Ethernet1/4      N5K-C5596UP
    8 entries were displayed.
  3. Determine the administrative or operational status for each cluster interface.
    1. Display the network port attributes:
      network port show -role cluster
      Show example
      The following example displays the network port attributes on nodes n1 and n2:
      cluster::*> network port show –role cluster
        (network port show)
      Node: n1
        Ignore
                                                        Speed(Mbps) Health   Health
      Port      IPspace      Broadcast Domain Link MTU  Admin/Oper  Status   Status
      e0a       Cluster      Cluster          up   9000 auto/10000  -        -
      e0b       Cluster      Cluster          up   9000 auto/10000  -        -
      e0c       Cluster      Cluster          up   9000 auto/10000  -        -
      e0d       Cluster      Cluster          up   9000 auto/10000  -        -
      Node: n2
        Ignore
    2. Display information about the logical interfaces:
      network interface show -role cluster
      Show example
      The following example displays the general information about all of the LIFs on the cluster, including their current ports:
      cluster::*> network interface show -role cluster
       (network interface show)
                  Logical    Status     Network            Current       Current Is
      Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
      Cluster
                  n1_clus1   up/up      10.10.0.1/24       n1            e0a     true
                  n1_clus2   up/up      10.10.0.2/24       n1            e0b     true
                  n1_clus3   up/up      10.10.0.3/24       n1            e0c     true
                  n1_clus4   up/up      10.10.0.4/24       n1            e0d     true
                  n2_clus1   up/up      10.10.0.5/24       n2            e0a     true
                  n2_clus2   up/up      10.10.0.6/24       n2            e0b     true
                  n2_clus3   up/up      10.10.0.7/24       n2            e0c     true
                  n2_clus4   up/up      10.10.0.8/24       n2            e0d     true
    3. Display information about the discovered cluster switches:
      system cluster-switch show
      Show example
      The following example shows the active cluster switches:
      cluster::*> system cluster-switch show
      Switch                        Type               Address         Model
      CL1                           cluster-network    10.10.1.101     NX5596
           Serial Number: 01234567
            Is Monitored: true
                  Reason:
        Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                          7.1(1)N1(1)
          Version Source: CDP
      CL2                           cluster-network    10.10.1.102     NX5596
           Serial Number: 01234568
            Is Monitored: true
                  Reason:
                          7.1(1)N1(1)
          Version Source: CDP
      2 entries were displayed.
  4. Verify that the appropriate RCF and image are installed on the new 3232C switches as necessary for your requirements, and make the essential site customizations, such as users and passwords, network addresses, and other customizations.
    Note
    You must prepare both switches at this time.
    If you need to upgrade the RCF and image, you must complete the following steps:
    1. Go to the Cisco Ethernet Switches page on the NetApp Support Site.
    2. Note your switch and the required software versions in the table on that page.
    3. Download the appropriate version of the RCF.
    4. Select CONTINUE on the Description page, accept the license agreement, and then follow the instructions on the Download page to download the RCF.
    5. Download the appropriate version of the image software.
      See the ONTAP 8.x or later Cluster and Management Network Switch Reference Configuration Files Download page, and then select the appropriate version.
      To find the correct version, see the ONTAP 8.x or later Cluster Network Switch Download page.
  5. Migrate the LIFs associated with the second Nexus 5596 switch to be replaced:
    network interface migrate -vserver vserver-name -lif lif-name -source-node source-node-name - destination-node node-name -destination-port destination-port-name
    Show example
    The following example shows the LIFs being migrated for nodes n1 and n2; LIF migration must be done on all of the nodes:
    cluster::*> network interface migrate -vserver Cluster -lif n1_clus2 -source-node n1 -
    destination-node n1 -destination-port e0a
    cluster::*> network interface migrate -vserver Cluster -lif n1_clus3 -source-node n1 -
    destination-node n1 -destination-port e0d
    cluster::*> network interface migrate -vserver Cluster -lif n2_clus2 -source-node n2 -
    destination-node n2 -destination-port e0a
    cluster::*> network interface migrate -vserver Cluster -lif n2_clus3 -source-node n2 -
    destination-node n2 -destination-port e0d
  6. Verify the cluster's health:
    Show example
    The following example shows the current status of each cluster:
    Cluster
                n1_clus2   up/up      10.10.0.2/24       n1            e0a     false
                n1_clus3   up/up      10.10.0.3/24       n1            e0d     false
                n2_clus2   up/up      10.10.0.6/24       n2            e0a     false
                n2_clus3   up/up      10.10.0.7/24       n2            e0d     false
What's next?
After you've prepared to migrate your switches, you can configure your ports.
