Install and maintain
Configure log collection for Ethernet switch health monitoring
Contributors netapp-yvonneo netapp-jsnyder netapp-aoife aclose-ntap
Configure log collection on your Ethernet switches to enable the Ethernet switch health monitor (CSHM) to gather switch logs for debugging and AutoSupport reporting. This procedure sets up both on-demand support log collection and hourly periodic data collection in ONTAP.
Before you begin
  • If you use FIPS mode, complete the following before setting up log collection:
    1. Regenerate SSH keys on the switch using the vendor instructions.
    2. Regenerate SSH keys in ONTAP using debug system regenerate-systemshell-key-pair.
    3. Re-run log collection setup using the system switch ethernet log setup-password command.
  • You must have access to the switch show commands. If you do not, create a new switch user and grant the necessary privileges.
  • Switch health monitoring must be enabled for the switch. Verify by checking that the Is Monitored: field is set to true in the output of system switch ethernet show.
  • For log collection with Broadcom and Cisco switches:
    • The local user must have network admin privileges.
    • Create a new switch user for each cluster with log collection enabled. These switches do not support multiple SSH keys for the same user, running setup again overwrites the existing SSH key.
  • For support log collection with NVIDIA switches, the log collection user must be able to run the cl-support command without a password. To allow this, run:
    echo '<user> ALL = NOPASSWD: /usr/cumulus/bin/cl-support' | sudo EDITOR='tee -a' visudo -f /etc/sudoers.d/cumulus
Steps
Follow the steps for your version of ONTAP to set up log collection, enable periodic data collection, and optionally request on-demand support logs.
ONTAP 9.15.1 and later
  1. To set up log collection, run the following command for each switch. You are prompted to enter the switch name, username, and password for log collection.
    NOTE: If answering y to the user specification prompt, make sure that the user has the necessary permissions as outlined in [Before you begin].
    cluster1::*> system switch ethernet log setup-password
    Enter the switch name: <return>
    The switch name entered is not recognized.
    Choose from the following list:
    cs1
    cs2
    Enter the switch name: cs1
    Would you like to specify a user other than admin for log collection? {y|n}: n
    Enter the password: <enter switch password>
    Enter the password again: <enter switch password>
    Enter the switch name: cs2
Note For CL 5.11.1, create the user cumulus and respond y to the following prompt: Would you like to specify a user other than admin for log collection? {y|n}: y
  1. Enable periodic log collection:
    system switch ethernet log modify -device <switch-name> -periodic-enabled true
    cluster1::*> system switch ethernet log modify -device cs1 -periodic-enabled true
    Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y
    cs1: Periodic log collection has been scheduled to run every hour.
    cluster1::*> system switch ethernet log modify -device cs2 -periodic-enabled true
    cs2: Periodic log collection has been scheduled to run every hour.
    cluster1::*> system switch ethernet log show
                                              Periodic    Periodic    Support
    Switch                                    Log Enabled Log State   Log State
    cs1                                       true        scheduled   never-run
    cs2                                       true        scheduled   never-run
    2 entries were displayed.
  2. Request support log collection:
    system switch ethernet log collect-support-log -device <switch-name>
    cluster1::*> system switch ethernet log collect-support-log -device cs1
    cs1: Waiting for the next Ethernet switch polling cycle to begin support collection.
    cluster1::*> system switch ethernet log collect-support-log -device cs2
    cs2: Waiting for the next Ethernet switch polling cycle to begin support collection.
    cluster1::*> *system switch ethernet log show
    cs1                                       false       halted      initiated
    cs2                                       true        scheduled   initiated
  3. To view all details of log collection, including the enablement, status message, previous timestamp and filename of periodic collection, the request status, status message, and previous timestamp and filename of support collection, use the following:
    system switch ethernet log show -instance
    cluster1::*> system switch ethernet log show -instance
                        Switch Name: cs1
               Periodic Log Enabled: true
                Periodic Log Status: Periodic log collection has been scheduled to run every hour.
        Last Periodic Log Timestamp: 3/11/2024 11:02:59
              Periodic Log Filename: cluster1:/mroot/etc/log/shm-cluster-info.tgz
              Support Log Requested: false
                 Support Log Status: Successfully gathered support logs - see filename for their location.
         Last Support Log Timestamp: 3/11/2024 11:14:20
               Support Log Filename: cluster1:/mroot/etc/log/shm-cluster-log.tgz
                        Switch Name: cs2
               Periodic Log Enabled: false
                Periodic Log Status: Periodic collection has been halted.
        Last Periodic Log Timestamp: 3/11/2024 11:05:18
         Last Support Log Timestamp: 3/11/2024 11:18:54
ONTAP 9.14.1 and earlier
    cs1
    cs2
  1. To request support log collection and enable periodic collection, run the following command. This starts both types of log collection: the detailed Support logs and an hourly collection of Periodic data.
    system switch ethernet log modify -device <switch-name> -log-request true
    cluster1::*> system switch ethernet log modify -device cs1 -log-request true
    Enabling cluster switch log collection.
    cluster1::*> system switch ethernet log modify -device cs2 -log-request true
    Wait for 10 minutes and then check that the log collection completes:
Caution If any error statuses are reported by the log collection feature (visible in the output of system switch ethernet log show), refer to Troubleshoot log collection for further details.
