Install and maintain
Complete the Cisco Nexus 3232C cabling worksheet
Contributors netapp-yvonneo netapp-jsnyder netapp-jolieg
Complete the cabling worksheet for Cisco Nexus 3232C cluster switches to document port connections and supported platform configurations.
The sample cabling worksheet provides examples of recommended port assignments from the switches to the controllers. The blank worksheet provides a template that you can use in setting up your cluster.
Each switch can be configured as a single 100GbE, 40GbE port or 4 x 10GbE ports.
Sample cabling worksheet
The sample port definition on each pair of switches is as follows:
Cluster switch A Cluster switch B
Switch port
Node and port usage
Switch port
Node and port usage
1
4x10GbE/4x25GbE or 40/100GbE node
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
40G/100GbE node 19
19
40G/100GbE node 19
20
40G/100GbE node 20
20
40G/100GbE node 20
21
40G/100GbE node 21
21
40G/100GbE node 21
22
40G/100GbE node 22
22
40G/100GbE node 22
23
40G/100GbE node 23
23
40G/100GbE node 23
24
40G/100GbE node 24
24
40G/100GbE node 24
25 through 30
Reserved
25 through 30
Reserved
31
100GbE ISL to switch B port 31
31
100GbE ISL to switch A port 31
32
100GbE ISL to switch B port 32
32
100GbE ISL to switch A port 32
Blank cabling worksheet
You can use the blank cabling worksheet to document the platforms that are supported as nodes in a cluster. The Supported Cluster Connections section of the Hardware Universe defines the cluster ports used by the platform.
Switch port
Node/port usage
Switch port
Node/port usage
1
1
2
2
3
3
4
4
5
5
6
6
7
7
8
8
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
19
19
20
20
21
21
22
22
23
23
24
24
25 through 30
Reserved
25 through 30
Reserved
31
31
32
32
What's next
After you've completed your cabling worksheets, you can install the switch.
