Install and maintain
Migrate from a switchless configuration with switch-attached storage to Cisco Nexus 9336C-FX2 shared switches
Contributors netapp-yvonneo netapp-karunesh netapp-jolieg netapp-jsnyder
Migrate from a switchless configuration with switch-attached storage to Cisco Nexus 9336C-FX2 shared switches by reusing the existing storage switches.
By reusing the storage switches the storage switches of HA pair 1 become the shared switches as shown in the following figure.
Switch-attached
Steps
  1. Verify that the storage configuration of HA pair 1 (and HA pair 2) is correct and error free:
    system switch ethernet show
    Show example
    storage::*> system switch ethernet show
    Switch                    Type                  Address          Model
    sh1
                              storage-network       172.17.227.5     C9336C
        Serial Number: FOC221206C2
         Is Monitored: true
               Reason: none
     Software Version: Cisco Nexus Operating System (NX-OS) Software, Version
                       9.3(5)
       Version Source: CDP
    sh2
                            storage-network        172.17.227.6      C9336C
        Serial Number: FOC220443LZ
         Is Monitored: true
               Reason: None
                       9.3(5)
       Version Source: CDP
    2 entries were displayed.
    storage::*>
  1. Verify that the node ports are healthy and operational:
    storage port show -port-type ENET
    Show example
    storage::*> storage port show -port-type ENET
                                       Speed                          VLAN
    Node    Port    Type    Mode       (Gb/s)    State     Status       ID
    node1
            e0c     ENET    storage          100 enabled   online       30
            e0d     ENET    storage          100 enabled   online       30
            e5a     ENET    storage          100 enabled   online       30
            e5b     ENET    storage          100 enabled   online       30
    node2
  1. Move the HA pair 1, NSM224 path A cables from storage switch A to the shared NS224 storage ports for HA pair 1, path A on storage switch A.
  2. Move the cable from HA pair 1, node A, path A to the shared storage port for HA pair 1, node A on storage switch A.
  3. Move the cable from HA pair 1, node B, path A to the shared storage port for HA pair 1, node B on storage switch A.
  4. Verify the storage attached to HA pair 1, storage switch A is healthy:
    system health alert show -instance
    Show example
    storage::*> system health alert show -instance
    There are no entries matching your query.
  1. Replace the storage RCF on shared switch A with the shared RCF file. Refer to Install the RCF on a Cisco Nexus 9336C-FX2 shared switch for further details.
  2. Verify the storage attached to HA pair 1, storage switch B is healthy:
    Show example
  1. Move the HA pair 1, NSM224 path B cables from storage switch B to the shared NS224 storage ports for HA pair 1, path B to storage switch B.
  2. Move the cable from HA pair 1, node A, path B to the shared storage port for HA pair 1, node A, path B on storage switch B.
  3. Move the cable from HA pair 1, node B, path B to the shared storage port for HA pair 1, node B, path B on storage switch B.
  4. Verify the storage attached to HA pair 1, storage switch B is healthy:
    Show example
  1. Replace the storage RCF file on shared switch B with the shared RCF file. Refer to Install the RCF on a Cisco Nexus 9336C-FX2 shared switch for further details.
    Show example
  1. Install the ISLs between shared switch A and shared switch B:
    Show example
    sh1# configure
    Enter configuration commands, one per line. End with CNTL/Z.
    sh1 (config)# interface e1/35-36
    sh1 (config-if-range)# no lldp transmit
    sh1 (config-if-range)# no lldp receive
    sh1 (config-if-range)# switchport mode trunk
    sh1 (config-if-range)# no spanning-tree bpduguard enable
    sh1 (config-if-range)# channel-group 101 mode active
    sh1 (config-if-range)# exit
    sh1 (config)# interface port-channel 101
    sh1 (config-if)# switchport mode trunk
    sh1 (config-if)# spanning-tree port type network
    sh1 (config-if)# exit
    sh1 (config)# exit
  1. Convert HA pair 1 from a switchless cluster to a switched cluster. Use the cluster port assignments defined by the shared RCF. Refer to Install NX-OS software and reference configuration files (RCFs)​ for further details.
  2. Verify that the switched networking configuration is valid:
    network port show
What's next?
After you've migrated your switches, you can configure switch health monitoring.
